Can this cam still be used on a turbo car? (Pic)
Can this still be used based on the damage in the photo? It's the intake side of a CTR cam. Opinions welcomed but please be specific in your explanation.
Thanks.
Pic of how the cam sits in the head minus the valve cover
Thanks.
can't, cams are cast and it would also require precision machine work to sit flat again.
hmotors sells individual R cams for less than acura new in the box, just buy one and be done with it
OEM cams are steel. Most aftermarkets are a chill-cast Iron. I'd still find another one. Hmotorsonline has them for 285USD
Yes have Golden Eagle adjustable cam gears....broke while was being pulled out of the head by an amateur....whats funny is the Gsr exhaust cam of the set i already had laying around fell off the shelf in the garage and snapped in half fml....
So now my question is does that chip affect anything when it doesn't touch anything? From what I can tell the distributor O ring does the task of keeping oil from leaking.. I would just hate to let a blemish stop use of perfectly good cams...
Anytime you take a physically damaged part and put it into a rotating assembly, you run a HUGE risk of damage from additional fatigue from it rotating. All I can do is warn you, DON'T RUN BROKEN PARTS.
cam wasnt dropped it likely was pulled out of the head incorrectly...even the machine shop guy said he sees it all the time people just put them back in and run them...told me the caps hold in cam but he doesnt recommend putting them back in... was just a stupid situation to be in since i already had a set of GSR cams & the Gsr exhaust cam fell off the shelf in the garage and snapped in half...so now im faced with a GSR intake cam & a CTR exhaust cam....
