Neptune & PTE 780cc Injectors
Old Nov 17, 2011 | 10:40 PM
MoreCowbell's Avatar
Default Neptune & PTE 780cc Injectors
I would like to get these going but have no clue on what to insert for the offsets. I have gotten the offsets directly from them which for whatever reason they dont want posted publicly. Anyhow I have 8 offset values given to me from them and none have a 0 voltage placement. Even if I plug in all PTE's offsets I am still left with 1 offset value I have not used from PTE.
Screenshot of the voltage offset area
http://screencast.com/t/IM6IR79uK25x
Thanks
Old Nov 18, 2011 | 07:50 AM
Default Re: Neptune & PTE 780cc Injectors
Any help without riddles would be great. I asked on the hr tuning site but the replies are almost sarcastic it seems.
Old Nov 18, 2011 | 08:27 AM
HRTuning's Avatar
The 0 voltage mark is necessary in case it ever drops below that 8.7 volt mark, it won't be able to use the compensation table if it drops below 8.7 volts.
Your system should never get below 8.7 volts.
If you're unable to extrapolate the values just leave it how it is. If you drop below 8.7 volts you have other problems to worry about.
This is what I said over several PMs to you and it's not to be taken sarcastically.
Old Nov 18, 2011 | 08:51 AM
I am very grateful to have the creator chime in to help and this is one of the reasons that made me switch to your engine management. I understand that answering newbies questions relentlessly must be tedious, when you have made a excellent help menu that's built right in the program.
Quite simply though the one liner PM's are not cutting it. Yes I am unable to extrapolate the values without previous experience playing with injectors. You said that I could just use what was given to me by PTE, but I have more values than are allotted in neptune. Also if I have to extrapolate the values does that not rule out what you said of just using what they give me?
Thanks for the help
Old Nov 18, 2011 | 09:30 AM
HRTuning's Avatar
My responses have covered your questions just fine and I'm sorry if you're unable to pick out what you're looking for specifically within what I've said. Perhaps different questions are in order because we're covering the same things. If you can extrapolate to cover all bases that's the best way to go. If you can't, then it will run with the values they've given you as long as you remain within the bounds you have for breakpoints. That means between 8.7 to 19.1 volts, which you should never be outside of anyway. I'm obligated to warn you, so I have. You get to decide how to proceed.
Old Nov 18, 2011 | 10:24 AM
So based on what I have in the screenshot in the first post and the PTE values I sent you, will that configuration work?
Old Nov 18, 2011 | 10:36 AM
HRTuning's Avatar
If you can't extrapolate then it will run with the values they've given you (Which is what you have entered) as long as you remain within the bounds you have for breakpoints. That means between 8.7 to 19.1 volts, which you should never be outside of anyway.
If you need that broken down any further can you specify where you're getting lost.
Old Nov 18, 2011 | 10:58 AM
Thank you for the help.
I will be sharing some info on the forum when more things are up to speed.
Old Nov 18, 2011 | 11:07 AM
HRTuning's Avatar
Sounds good. I'll keep an eye out. If you have any other questions start a thread on the forum. I like to be able to see the history of the conversation, which PMs don't always offer.
boostedteg4dr
Dec 16, 2013 08:59 AM
The sweed
Dec 30, 2008 05:25 AM
Race Egr
Welding / Fabrication
11
Jun 28, 2005 09:06 AM
