bigger tire/rim size affect mph?
found a calculator so just double checking if this is right. if there is any loose ends then let me know. as far as ive read and understood, the tire size can affect your mph correct?
a site told me the stock 93 civic dx tire size is P175/70R13.
i now have 15" rims with p195/60r15 snow tires on. the online converter took the diameter size of 13" rims to 15" rims and when my spedometer now reads 80mph, it should really be reading 92mph.......??? if this were true that would mean i have the longest gearing in all of honda history. my 1st gear goes to 50ish, my second gear goes to 80ish, if it actually goes all the way to 92 then im baffled. or is the calculator backwards saying that when my speedo is showing 80 im really going 70..
heres the links to the sources:
http://www.dragtimes.com/Honda-Civic...-m18-n214.html
http://www.onlineconversion.com/bigger_tires.htm
that calculator must be off. i have 18" wheels with 215/45/r18 and im only a few mph off from stock. ride next to a friend on a 2 lane highway and have them hold a steady speed at 50mph and try to steady your car next to theirs. if anything u may be 5mph off not 12mph. if u put a stock tire next to your rims im sure the overall diameter is damn near the same. maybe if u were running the same profile tire from your 13" wheel on your 15" wheel it would be a few inches bigger and yes it would prob be 12mph off. when you run 15's you have a lower profile tire then stock.
Your speedo says you're doing 80 when you're actually doing 89.14285. However, if you notice every guage cluster will be 3-4mph faster than actual speed due to DOT regulations. You can also buy a speedohealer to calibrate your speedo.
and that means that my gearing is actually even alittlbe bit longer than i tohught.......if i ever did a 1/4 mile id probably be finishing in high 2nd low 3rd gear LOL
yes well the new tires are 15r's they have somewhat thick tread as well. yea i was planning on doing the friend test tomorrow but was just curious tonight, and can u rent a speedohealer? i see theyre a good chunk of change. ididnt know if auto zone had one i could just rent out.
15 r means the inner diameter, meaning it's a 15inch wheel, 16r means 16" wheel. The "sizing" you're looking for is the first number. p195 or p175 That is the size of the tire in millimeters.
The unsprung weight of the larger wheel will also have a negative impact on mileage and a lot of impact on acceleration AND affects the speedo.
so youre saying that even thought the spedo was calibrated for a 13 inch wheel and that now i have a 15 inch wheel
that doesnt matter, its only the difference of p195 and p175? and through your calculations my spedo should be reading 89ish when its reading 80mph correct?
o alright and sorry, i thought the speedohealer was just something you could rent and it would just like recalibrate the spedo i didnt know it was a permanent addition.
The P195 is the width of the tire in millimeters. The 60 is the aspect ratio which is essentially, the height of the sidewall in proportion to the width. A P195/60r15 will be taller than a P195/50r15 and therefore have a larger rolling circumference. The calculator you posted the link to does not factor that into their formula. That calculator is assuming the sidewalls are the same height which they are not. Your snow tires are def bigger than your originals, which is going to affect your speedo. This link i posted is a more accurate calculator an will answer your questions.
http://www.miata.net/garage/tirecalc.html
