MANUAL -> POWER WINDOW
Found someone parting out a 92 Integra sedan (DB1). Similar to mine but it has power windows. Was wondering if I could pull out his power window motor, regulator, relays, switches and drop it into mine. Am I going to have any problems installing it ? or will it just slide right in….
Ditto the above^^^
You will need the power window regulators/motors, door wire harnesses, door panels, power window switches, and dash harness, power window relay. 94
If I gather all of that, then there will be no problem sliding everything into my car and wiring it up right? I have manual windows. Was wondering if I could have the luxuries of having power windows if its simple to install once I get all the pieces. lol
For 94+ integras everything is prewired. Ex: You can install AC into a non-ac car and all the buttons magically work. I hope its somewhat similar for DBS. Technically if you have a donor car you should just follow the bolt holes, wiring, etc, and you are golden
Are the complete door harnesses there?
I do not see the dash harness, I am not sure if you need a dash harness on a G2, easy enough to check, unplug one of your door harness plugs at the A piller, pull the dash harness end of the plug out of the A piller, see if all the lead you need, [match the power window door harness you have] are there, if so, probably all you will need is the relay and fuse(s).94
civiceg94
Jul 10, 2007 12:27 PM
gleinz
27
Mar 2, 2003 06:06 PM
