rota grid - would these fit on 98 civic?
Old Nov 17, 2011 | 02:47 PM
98EJ7Y8's Avatar
Default rota grid - would these fit on 98 civic?
http://www.ebay.com/itm/ROTA-WHEEL-G...ht_2326wt_1177
would these fit on my 98 civic hx with eibach lowering springs on it?? i think the offset may be a little too outrageous lol ..
Old Nov 17, 2011 | 03:14 PM
QuicksilverFX's Avatar
Default Re: rota grid on 98 civic
i would never put anything bigger than a 16 on a 96-00 civic
Old Nov 17, 2011 | 03:18 PM
98EJ7Y8's Avatar
my question was will a 9 inch wide tire fit on a 98 civic and what is the lowest offset i can go .. not what size you prefer ..lmfao!! but i agree nothing ever bigger than a 17 ever
Old Nov 17, 2011 | 03:39 PM
grumblemarc's Avatar
The Grumpiest
9" wide? Fit? Hell no.
Old Nov 17, 2011 | 04:00 PM
98EJ7Y8's Avatar
thanks .. and what would an agressive offset be i can go with ??
Old Nov 17, 2011 | 04:49 PM
NazVil86's Avatar
as far as "fit" what do you mean- you'll have to roll the fenders, and adjust that camber a bit, and depending on the offset might need a spacer/ext wheel studs.
I came into a deal for some 16x9 +30 rims. when put on noticed the inside of the rim was pressed up against the trailing arms- 5mm spacer helped that- then had to go with extended wheel studs as well. Camber kit comes in soon- even at that, they didn't poke out as bad as it seems. this is on a em1 btw.
i can pm you pictures if you'd like.
Old Nov 17, 2011 | 10:02 PM
98civdx's Avatar
Master Detailer
They wont fit, not easily any way.
Those are really wide, and low offset, and 17's. PASS.
Old Nov 17, 2011 | 11:36 PM
Dakota D16z6's Avatar
Those are Sick!
Old Nov 18, 2011 | 01:08 PM
98EJ7Y8's Avatar
yes if you could please .. i really like the offset of the rotas i posted but its only a 20 so maybe a little too much .. lol .. too bad civics cant get that low of an offset .. or would it be possible?? .. but even if its a 16 i want that offset or an offset that looks similar
Old Nov 18, 2011 | 01:12 PM
JDM-Punk's Avatar
why do you need a 9" wide wheel?!
if you were to shrink your size both height and width, then you might be able to actually find wheels that can fit
Old Nov 18, 2011 | 01:16 PM
98civdx's Avatar
Master Detailer
You can run the +20, but come on, a 17x9?
You can low offset on these cars, but it will require quite a bit of negative camber, and fender rolling.
And that point, your ****ing up the car just to put these peice of **** wheels on it. Is it really worth it?
Old Nov 18, 2011 | 02:25 PM
98EJ7Y8's Avatar
lmfao!! thats exactly what im saying .. what is the max offset and width i can go without having to roll my fenders or adjust the chamber and all that good stuff.?? i would like to get a 17x9 only cause they had the offset and look i wanted .. seems to me that the smaller the tire and rim the less agressive it looks.. i just want a rim that is gonna look like the ones in the link i posted .. i am planning on getting a 16x7.5 but cant find any with an offset i like
Old Nov 18, 2011 | 05:35 PM
The Grumpiest
What? If you're looking for 16x9 (which I think is STILL stupid) why did you link to a 17" wheel?
Old Nov 18, 2011 | 06:39 PM
LSVTEC96HB's Avatar
17x9 +20 would look right on an EVO or something, but not a civic. You'd have a tough time making them work, and it would be hellanonfunctional. I put 16x8 +38 on my '99 and it looks very aggressive, and the wheels don't stick out past the fenders.
Old Nov 18, 2011 | 07:03 PM
98EJ7Y8's Avatar
im looking for a 16x7.5 but i was just wondering what would be the max i can go for offset and width .. i guess the 17x9 was just an example for the offset or the look i wanted ... but thanks lsvtec96hb thats the answer i was looking for
Old Nov 18, 2011 | 07:04 PM
98EJ7Y8's Avatar
any chance you can post a pic of the wheels ??
Old Nov 18, 2011 | 08:46 PM
98civdx's Avatar
Master Detailer
if you cant find the offset you like, go a little higher and just fine tune it with spacers.
Old Nov 26, 2011 | 06:56 PM
One92Eg6's Avatar
Default Re: rota grid - would these fit on 98 civic?
whats wrong with this guy?
Old Nov 26, 2011 | 07:01 PM
Wrona's Avatar
He wants to be hella mad tyte jDm y0
Old Nov 26, 2011 | 07:05 PM
hyperblu's Avatar
Old Nov 26, 2011 | 09:13 PM
Libertariat's Avatar
Ek Forever y0!
There is absolutely nothing outrageous with a +20 offset.
There is everything outrageous with a 9" wide wheel on a gas sipping econo-box compact car.
Will it fit? Sure. Will it function? No.
You're basically asking whether or not a hot-dog will fit through the eye of a needle. Will it fit? Sure. But it won't be pretty.
P.S. And you can't have a delicious hot-dog with onion and spicy brown mustard afterward. At least not with any composure.
Old Oct 22, 2019 | 11:56 AM
Sean Harrison's Avatar
I’m looking at 15x7 +20 rota grids for my em1 and don’t want to roll the fenders or have a bunch of camber. Will it work with a 205/50 tire?
Old Oct 22, 2019 | 10:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
NOPE. You will need a +41mm 15x7 to fit as you have asked... no rolled fenders and proper camber.
98EJ7Y8
Jun 4, 2012 04:31 PM
RiceBurninCX
Jan 30, 2008 11:13 PM
ProjectSi
Dec 13, 2007 04:07 PM
YipMan_Style
Jan 24, 2002 08:19 AM
