electrical problem blinkers flashers brake lights hazzards
Ok guys I bought an 96 Ek hatch has a k20 in it but not wired up the shell had been stolen bunch or wires cut so I bought a 98 civic dx harness (which included headlights harness dash harness and the wiring behind the dash......installed all of it .....have no brake lights no dash lights no hazard lights and no turn signals the car doesn't have headlights or front running lights ...what could be wrong....thanks another thing if I send a direct 12 volts to each individual tail light the work same goes for the blinkers however they don't flash because its not running through the flasher....when I turn the flasher on nothing happens ......also when I jump the brake light switch the brake lights stilk don't cone on ....this is driving me crazy
Update got the flasher working however passenger side doesn't flash but driver side does bulb is good the wire was broke for the hazzard switch right behind the switch
maybe explain how u fixed the flashers that were not working before. was it a ground or fuse? it could be a bad relay or something as well.
Ok guys fixed the blinkers and tail lights ....there were 2 broken wires in the harness I bought ....I made the tail lights work by taking the green and white wire for the brake lights and just wired it into the brake light switch....problems now discovered are when i turn the flashers on only the right one flashes but if I turn the left blinker on they both flash.....also fuel pump isnt coming on gonna test the main relay to see if its good
motoman32002
Nov 17, 2011 05:07 AM
