Attn: 4 door & 2 teg's owners camber kit or stock uca
Old Nov 17, 2011 | 10:35 AM
BAY_99DB8LUV's Avatar
Default Attn: 4 door & 2 teg's owners camber kit or stock uca
So hears my question: my 4 door Teg came with eBay camber kit & not sure what setup Teg owners are running? Stock uca or aftermarket camber kit? I upgraded my suspension to function & form type 1 & not slammed but low enough, seems like every major bump the tires are smacking camber kit. I heard that a lot of people who ride low, run stock uca vs camber kits... So need some advice since I want to replace everything now. Also I'm running 195/50/15 tires on si rims right now. Any info would help... Thanks
Old Nov 17, 2011 | 10:37 AM
kyden's Avatar
Default Re: Attn: 4 door & 2 teg's owners camber kit or stock uca
there's no way the tire can hit the camber kit... you sure it's not hitting the shock tower?
Old Nov 17, 2011 | 10:38 AM
TunerN00b's Avatar
1) we have a sticky about this in the suspension forum. https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
2) 195/50-15 is the wrong tire size. Your speedometer and odometer readings are off.
Old Nov 17, 2011 | 10:45 AM
@kyden: I think the camber kit is hitting the shock tower, but also tires rubbing too. I think when I camber kit hits the shock tower, tires are rubbing camber kit. Also when I'm coming off a freeway where it's super bumpy, I can smell tires that have been rubbing. So my question is would a stock uca be better than a qaulity camber kit? The issues might be that since its a cheap kit, it isn't stiff as it should.
Old Nov 17, 2011 | 11:03 AM
fcm's Avatar
fcm
Old Fart
A "quality" camber kit will be better then a stock UCA, but the stock UCA is a lot better then a cheap camber kit.
Unless you are dropping the car to the ground, a camber kit is not needed, a little extra camber will not hurt anything, just make sure you get a four (4) wheel alignment once you have the suspension system you want and the "drop" you want. 94
Old Nov 17, 2011 | 12:46 PM
Anyone ever run hardrace camber kits? Leaning towards them or skunk 2 pro series .
Old Nov 17, 2011 | 05:22 PM
Navy_Kyle's Avatar
ebay camber kit is alright if you dont wanna spend that much but i wouldnt recommend it and many other ppl will tell you too but myself i wouldnt get one from there youre better off spending the money and getting a quality camber kit that will last, skunk2 and blox are some of the best, my teggy has a blackworks racing camber kit there a newer company but its a good product
kasperxtcy
Suspension & Brakes
Nov 6, 2007 10:19 AM
pr0phet
Nov 22, 2005 03:59 PM
JunIntegra
Apr 4, 2004 09:09 AM
Jowee
Dec 11, 2002 12:51 PM
stspj
May 28, 2002 07:21 PM
