canister and purge valve removed
Old Nov 17, 2011 | 07:03 AM
carlos8's Avatar
Default canister and purge valve removed
hi, i bought a 97 ex and swap all my ls vtec turbo, sometimes i feel a strong
gas smell. I check for leaks and nothing then i realize the car not have purge
system the hard line is plug with a screw, when the car is running and shaking
and you stop at a ligth the smell it's hard. Only thing on mind is route a 3/8"
line to the turbo inlet but need to fab a pipe cause i use the filter direct on the turbo.
Old Nov 17, 2011 | 08:52 AM
apexi_rsx's Avatar
Default Re: canister and purge valve removed
mines ran this very same way (wire and brake tuck)and i dont have any harsh gas smells. i dunno why yours would be any different. mines turbo as well.
Old Nov 17, 2011 | 09:02 AM
carlos8's Avatar
my guess is the screw isn't hold all the gases it's safety put a ruber plug with
a clamp.
Old Nov 17, 2011 | 10:35 AM
apexi_rsx's Avatar
i actually do not have mine plugged i have it still venting to outside air. maybe try that and see how that works
teg_racer
Sep 7, 2010 04:50 PM
t25d16a6
Jan 29, 2006 02:32 PM
raiden571
May 6, 2005 10:29 AM
91tegrals
Mar 2, 2004 07:34 AM
Ri5e
Feb 11, 2002 08:33 PM
