B16A Crankshaft Oil pump pulley seized?!? (Pics)
Was trying to remove the Crankshaft from the block on my JDM B16A and found this:
I did search but couldn't find anything that specifically referenced this problem nor solutions.
It appears to maybe have jumped timing at some point. I was able to remove the balancer pulley with no problem and the rectangular key has no signs of being broken. Question is how do I remove the pulley? Has anyone ever had this problem, and should I even bother re-using this crankshaft for my build? It's going to the machine shop for my 650hp build just wanted some opinions or possible removal tips
Thanks.
Thanks.
http://i387.photobucket.com/albums/o...91KA8/1234.jpg
http://i387.photobucket.com/albums/o...991KA8/key.jpg
nope, you are still good, the line and the key are not aligned, just grab a gear/bearing separator and pull it off.
OP you should get the timing belt guide plates too.
TurboEM1
May 2, 2006 09:56 AM
