I know its almost winter but I have an A/C question
Last summer I tried to fix my ac which I don't know how long it hasn't worked for. But I went ahead and bought a cheap retrofit kit that came with a hose to put in the R134 and some pag oil and fittings. A couple of things I neglected to do was the drier, orifice tube, and all the o-rings. But long story short it stopped working 2 days later. Could there be leak at the o rings? O yeah I did put a can of stop leak and red dye. I couldn't see any red dye but there was oil around the compressor. Is that dye only visible with black light? But there was a big stain right under the compressor the next day, which is still there over 3 months later. Is there something I'm missing? I put in 2 12oz cans of R134. And I can't remember how much pag oil it was a real small can. So is it just the o rings or is it a bad compressor?
One more thing was when I first started the ac no matter it it was on all day or not I got a weird smell kinda like mildew but sweeter, could it be the evaporator.
Please help me out!
Please help me out!
Please help me out!
Please help me out!
You got what you paid for-cheap retrofit kit
.For the real troubleshooting you will have to bring the car to a/c guys.There are too many things involved to make a quick diagnosis!Otherwise said, if you have a small puncture in the tire you can still drive as far as putting the air in it,but it doesn't fix the problem.
yes bad o-rings can allow all the freon and oil to leak out
at this point i would pull every piece of the system and clean the lines, condenser and evaporators, replace the expansion valve and drier and get a rebuilt compressor.
then pull a vacuum and make sure it holds for a few hours, then charge the system with r134.
flanker
Mar 7, 2016 12:45 AM
