Del Sol - D16z6 - Vtec won't engage
Old Nov 16, 2011 | 01:34 PM
HuchNet's Avatar
Default Del Sol - D16z6 - Vtec won't engage
I just bought the car like 2 months ago, it has been licking oil from the cam gear and the distributor also. I took it to the local shop and they replaced all the seals, stopped licking but now Vtec won't engage also it's very slow now.
What can it be?
Old Nov 16, 2011 | 01:39 PM
Wrona's Avatar
Default Re: Del Sol - D16z6 - Vtec won't engage
how does a car lick oil... is your vtec solenoid pugged in... i can see a mechanic unplugging it and forgetting abouot it..
Old Nov 16, 2011 | 01:49 PM
HuchNet's Avatar
It's plugged in..
What else should I check?
Old Nov 16, 2011 | 04:37 PM
hyperblu's Avatar
Take it back to the mechanic.
Old Nov 16, 2011 | 04:44 PM
Jdubbs6101's Avatar
Check your oil level vtec needs oil pressure to engage if you are low on oil it won't ever come on also are any CEL codes coming up some things to looks for are vehicle speed sensor and throttle position switch if it's none of that then deff take it back to the mechanic who did the work and ask him what he did
Old Nov 16, 2011 | 05:58 PM
Dioxine's Avatar
I would check and make sure they didnt pull any wires loose. I could see them doing that to.
Old Nov 20, 2011 | 09:00 PM
Resurrected_EJ's Avatar
could be a bad pressure switch ..... i had that problem it threw no code relating to the switch but in the end thats what it was
hondahead'
13
Aug 3, 2009 07:11 AM
high_octane
Jun 16, 2009 01:55 PM
jbell
Mar 5, 2006 06:34 PM
-Whitey-
12
Feb 4, 2003 01:24 PM
01-1293
Oct 9, 2002 03:03 PM
