97 accord cold air
Old Nov 16, 2011 | 12:23 PM
onefootinhell's Avatar
Default 97 accord cold air
hi i'm new to honda-tech, i installed a cold air intake on my accord and was wondering if they make the car harder on fuel or if i just have another problem
Old Nov 16, 2011 | 12:42 PM
StreetsideStig's Avatar
Default Re: 97 accord cold air
I think the only way it would hurt your fuel efficiency is if the filter is too far gone. It's probably something else. What kind of mileage are you getting?
Old Nov 16, 2011 | 12:55 PM
nicolaselias's Avatar
Loved
Community Favorite
maybe since you installed the cold air intake you are on the throttle more than usual to enjoy the noise...
Old Nov 16, 2011 | 12:57 PM
i just noticed the rear o2 sensor plug is broke so it's not hooked up, but doesn't that sensor just tell you when the cats bad?
Old Nov 16, 2011 | 08:36 PM
nus_dogg's Avatar
Bank1 Sensor 2 just measures 02 after the cat.
Old Nov 17, 2011 | 10:47 AM
Is your check engine light on? If so, you might be in limp mode, which drastically reduces your gas mileage. Fix the sensor plug and reset the computer.
Old Nov 19, 2011 | 07:13 AM
yes it is on, thanks i'm gonna try to fix it now
Old Nov 22, 2011 | 12:11 PM
Did it work?
Old Nov 22, 2011 | 12:27 PM
gogydm's Avatar
Do you know what code it was throwing? And having a cold air will not make your mileage worse, it might actually improve it. When I put my AEM short ram I felt a slight increases in MPGs with the same driving style.
Old Nov 22, 2011 | 02:35 PM
sorry i didn't get back sooner, it was throwing code 63, secondary o2 sensor, got it wired up right and engine light off thanks for the help guys
Old Nov 22, 2011 | 10:41 PM
holmesnmanny's Avatar
Usually with the added power when the car is warm, people usually run it harder, thereby negating any + mpg.
I know this from experience.
Old Nov 23, 2011 | 10:05 AM
Glad you got it figured out, man. Let us know if you're still having mileage problems.
Old Nov 25, 2011 | 12:25 PM
3 days no check engine light, then comes on again today same code 63
Old Nov 25, 2011 | 01:27 PM
Did you pull the sensor itself? They burn out after a while. How many miles are on your car?
Old Nov 25, 2011 | 02:11 PM
442,000 kms
Old Nov 26, 2011 | 07:28 AM
SL33Pr_ProjeK's Avatar
442,000 kms
<-----likes this
Old Nov 29, 2011 | 07:57 AM
442,000 kms
Yeah, if that's the original sensor, I'll be surprised if it's still working.
Old Nov 29, 2011 | 12:25 PM
yea i was thinking the same
nelsond
Jun 13, 2006 06:21 PM
nObOdy65
Feb 15, 2006 11:44 PM
blackmagic08
Jan 25, 2005 11:51 AM
SofireGuy
Jan 5, 2005 09:39 PM
charjacq
Nov 25, 2002 06:43 PM
