is db8 b18c possible to use mugen ecu(for eg6)
Old Nov 16, 2011 | 07:28 AM
gtimax's Avatar
Default is db8 b18c possible to use mugen ecu(for eg6)
I saw the connector plug is the same and some guys said it is useable but don't know what is the effect.....
I wish to know the fuel injuction ok or not?
will it better than my stock ecu?
will it cause problem for long term use?
thanks a lot!
Old Nov 16, 2011 | 07:30 AM
kaiba's Avatar
Default Re: is db8 b18c possible to use mugen ecu(for eg6)
Real mugen? Probably Mugen ebay chip.
Old Nov 16, 2011 | 09:50 AM
iH8RICERZ's Avatar
Either way if its ebay mugen or the real mugen, I'm assuming your motor isn't built right? You will see probably a 1-5 whp increase on the dyno but your motor will be running extremely rich and your gas mileage will be ****! Your best bet, stick with your stock ecu until you really "build" your motor (ie. cams, head work, pistons, etc) then get your set up tuned on the dyno from a professional tuner.
santacruzccs
Jun 29, 2008 01:07 AM
THALADOR
Feb 23, 2005 06:23 AM
spyz34
May 5, 2004 10:09 PM
jdmjeff
Nov 10, 2003 04:06 PM
evo
Jan 3, 2002 10:54 AM
