Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
what will be the best swap i could put on my 01 civic lx
Old Nov 15, 2011 | 10:46 PM
civic1990133's Avatar
Default what will be the best swap i could put on my 01 civic lx
I have a 01 civic lx two door what will be the best swap I could put on it and a good automatic tranny.
Old Nov 16, 2011 | 04:47 AM
toyomatt84's Avatar
Sanji
Default Re: what will be the best swap i could put on my 01 civic lx
If you want to stay with an automatic transmission, you're stuck with using a D17. You'll get slightly more hp from a D17A2 out of an EX model Civic... but the gains are negligible. If you want to gain noticeable hp, check the FAQ's thread on engine swaps. This has been covered before, countless times.
Old Nov 16, 2011 | 02:20 PM
Default what will be the best k series for my car
What will be the best k series and transmissions to put on my 01 civic lx
Old Nov 16, 2011 | 02:55 PM
MindBomber's Avatar
Default Re: what will be the best k series for my car
k20z1 or k24a2
Old Nov 16, 2011 | 07:31 PM
88CRX951's Avatar
I OLD SKOOL
I wonder if anyone has ever done an automatic K swap into an EM2/ES1/ES2
Old Nov 16, 2011 | 09:56 PM
jmvtec05's Avatar
^ i really don't see the point of an automatic k swap... i mean, for the money you spend on the swap, you would think everyone would go 6 spd...unless you won the lottery or somethin and you have money to blow.
Old Nov 17, 2011 | 06:14 AM
hondaluver's Avatar
anything is better than your d17
Old Nov 17, 2011 | 07:48 AM
toyomatt84's Avatar
Sanji
In order for the transmission to fit, you'd have to do some notching on the frame rails. Also, you'd need to get the K20A3 automatic transmission axles, if you want to retain your stock brakes. It's a huge amount of work for an auto-swap, especially when you consider the necessary changes to the wiring harness.
I suggest doing some research. Start with the FAQ's here: https://honda-tech.com/forums/honda-civic-2001-2005-78/faqs-guidelines-read-before-posting-2101211/
"Best" is such a relative term, that its impossible to answer accurately without knowing more details in to what goals you're looking to achieve.
Hondagallan
Apr 29, 2019 05:37 AM
sibiryak70rus
Dec 23, 2015 09:11 PM
Jose Castillo
Honda Civic (2006 - 2015)
Sep 2, 2015 01:16 PM
nc_mx_kid
Jul 21, 2004 09:28 AM
