D16Z6 dizzy firing order HELP ME!!!!
Old Nov 15, 2011 | 10:33 PM
trickshift's Avatar
Default D16Z6 dizzy firing order HELP ME!!!!
ok one of the weirdest things ive ever seen. My dizzy firing order is backwards. My friend noticed it first. My order is
his is
just like it should be in the book. I tried to hook mine up like his and my car spun over and backfired and woulndt crank. Whats my problem this is beyond strange
all of my Z6 buddies have the correct order but me. Help me please.
Old Nov 15, 2011 | 10:42 PM
trickshift's Avatar
Default Re: D16Z6 dizzy firing order HELP ME!!!!
heres some pics
Old Nov 15, 2011 | 10:45 PM
91efbluehatch's Avatar
yours is right. his is wrong.
google and google images are your friend.
Old Nov 15, 2011 | 10:51 PM
your wires are ALL JACKED UP
on your valve cover it should be like this
dizzy-#4 #3 #2 #1 timingbelt
the on your dizzy it should be like this
Old Nov 15, 2011 | 10:54 PM
and im also sure your dizzy is 180 out...
Old Nov 16, 2011 | 01:35 AM
HondaPartsHero's Avatar
Technical Hero
Old Nov 16, 2011 | 06:32 AM
trickshift's Avatar
How can it be 180 off? the rotor and dizzy only fit one way. This is beyond me. Its been like this since i got the car
Old Nov 16, 2011 | 06:38 AM
Linked's Avatar
your dizzy isn't rotated out, thats how mine looks
but the sequence is
---3---
1-----4
---2---
Old Nov 16, 2011 | 07:24 AM
trickshift's Avatar
Right. But how do I fix this? Its obviously not correct. I just wonder what someone did to make it like that. How do I fix it? What's the issue?
Old Nov 16, 2011 | 08:05 AM
Technical Hero
You have the wrong wires going to the wrong cylinders. Take them all off and start over. The longest wire goes to #1, next shortest to #2 and so on. Here's a better shot of the z6.
Old Nov 16, 2011 | 10:03 AM
trickshift's Avatar
nah dude you dont understand my car runs the way it is in the pics i posted thats whats weird. if i hook them up like you guys are telling me the car wont start
thats my order and thats the way my car runs. i dont get it
trickshift's Avatar
i drive every day. good power good mileage. its just 180 off. why?
Old Nov 16, 2011 | 10:05 AM
grumblemarc's Avatar
The Grumpiest
Does it matter? If it's working? See post #8.
Old Nov 16, 2011 | 10:19 AM
trickshift's Avatar
Not really i guess. just worried about tuning for boost. Its just not how it was from Honda which bothers me
Old Nov 16, 2011 | 10:33 AM
P
Put your wires in the correct order.
Put your motor to TDC. Make sure the end rotor on the dizzy is lined up
Then unscrew the bolt on your rotor and put the rotor or spin it to where it is right on the #1 cyl.
Your dizzy is 180 out whether you know it or not but do like I said and time everything and you should be running right
Old Nov 16, 2011 | 10:39 AM
Nooch's Avatar
Originally Posted by 91efbluehatch
P
Agreed. Flip your numerical firing order 180 and you have your buddies 'correct' order. This is so ****ing basic & simple I don't understand how you or your friends have yet to catch this.
Flip your dizzy 180 since it is obviously upside down.
Old Nov 16, 2011 | 01:07 PM
apexi_rsx's Avatar
i don't know how the hell it can be 180 out one groove is bigger then the other for a reason that this cant happen unless you force it. his order is correct your order is 180 out and im surprised it even run's this way. you should check the internals of the dizzy to make sure it has the correct rotor on it.
Old Nov 16, 2011 | 04:54 PM
trickshift's Avatar
we arent dumb lol and you cant flip the dizzy it only bolts one way and the key is offset so you cant be wrong thats why i was confused. and usually the rotor has a groove so it only fits one way also
trickshift's Avatar
will do i'll recheck all this and see whats up thanks guys!
Old Dec 8, 2011 | 02:35 PM
1994civi's Avatar
I just had the same problem, you have the wrong dizzy on your car. IDK from which car but its the wrong one heres the reason why, your firing order is backwards because the rotor is 180 degrees off, make sure on the new one the rotor points in the opposite direction. Of course your car will still start because the firing order is correct for the old dizzy. You will gain more power too!
Old Dec 8, 2011 | 08:44 PM
One92Eg6's Avatar
that's what i was going to say.... Wrong Distributor. Get the right one for your motor. Problem solved.
Old Jul 25, 2020 | 05:26 PM
jhaluska's Avatar
Icon3 Re: D16Z6 dizzy firing order HELP ME!!!!
I hate to revive a dead thread, but this one shows up when searching for the problem. If your wiring is "wrong" but the car runs, the distributor's cam shaft was put together 180 degrees out of phase. To fix it, you take the distributor off, undo the clip on the cam shaft housing enough to push the pin out, rotate it 180 degrees and put it back together. This
has a good example. Doing this revived a dead car for me that had me stumped for a long time. I believe it was because the injectors and spark plugs are no longer paired correctly and the ECU eventually got so confused trying to adjust them to the point the car no longer ran.
tundra2000
Apr 19, 2011 03:06 PM
CivicxTree754
Jan 12, 2011 06:26 AM
user 98292739
Jun 6, 2005 04:15 AM
93slmdcvcsi
Sep 22, 2003 10:25 AM
