99 si/b18c1 boosted swap with high surging idle
Old Nov 15, 2011 | 08:59 PM
Got..BOOST??'s Avatar
Default 99 si/b18c1 boosted swap with high surging idle
bought a 99 si with a b18c1 boosted swap and cannot figure out how to fix the idle problem. it idles from 1500 to 2000 and its annoying what can be the cause of that??? tps maybe or not enough fuel pressure. also when i go to hit vtec the check engine light comes on for a second, it also boggs out when the light is on...
Old Nov 16, 2011 | 05:14 AM
Former User's Avatar
Default Re: 99 si/b18c1 boosted swap with high surging idle
Pull the CEL code.
Have you checked for a vacuum or intake air leak?
Old Nov 19, 2011 | 12:00 AM
No cell no vac leak and no intake leak
Old Nov 19, 2011 | 05:28 AM
Explain your certainty here^.
Also do this test: Remove the air intake and use your finger to cover the hole inside the throttle body leading to the IACV or FITV. Does covering one of these holes make the idle speed settle down?
Old Nov 19, 2011 | 05:34 AM
Chopped550's Avatar
If I were a betting man, I'd put money on a vacuum leak. It's bogging in vtec because it's leaning out and can't compensate for the un-metered air. Your CEL is probably a lean code.
Old Nov 19, 2011 | 05:52 AM
grumblemarc's Avatar
The Grumpiest
Are you tuned on <CROME>? There's a known issue with this. I have this from time to time.
PwrdByVtec_EM1
18
Oct 1, 2011 08:03 AM
ilovemyh22
May 6, 2009 12:54 PM
twisted civic
Jul 19, 2008 11:09 AM
vics_si
10
May 16, 2006 10:41 AM
