car just shut off.
Old Nov 15, 2011 | 07:10 PM
blacklabel14's Avatar
Default car just shut off.
i was driving and right when i put it in 3rd it died and now it wont start. it has gas and it starts to start but wont crank over. what could be wrong??
Old Nov 15, 2011 | 07:41 PM
Wrona's Avatar
Default Re: car just shut off.
check if its getting fuel and spark that is the first thing i would check
also you did not provide enough information about what car it is...
i would be guessing distributor because thats what happened in my old 97 integra LS Special Edition took off the light and boom car died tuned out to be the coil
inspect the distribuor cap for black spots
Old Nov 15, 2011 | 07:56 PM
Ef Hatch 34's Avatar
that's so vague... can you further explain? what was it doing before it died? any symptoms you noticed? does your fuel pump prime when you turn the car on?
Old Nov 16, 2011 | 12:30 AM
mark@silbernage's Avatar
I agree - when I've lost coils (long story) it's gone just like you describe. You can replace the coil only if that's the bad part - way cheaper than a new dist.
It's helpful if you have a volt/ohm meter and know how to use it - to diagnose the ignitor and coil.
Mark
Old Nov 16, 2011 | 12:51 PM
sorry guys i have a 1998 integra non vtec. the car was running perfectly normal right before it died. and when it did die it did the same thing as if u were to stall your car
Old Nov 16, 2011 | 12:53 PM
yea my fuel pumps pump primes
Old Nov 16, 2011 | 01:15 PM
Wrona's Avatar
Originally Posted by Wrona
check if its getting spark that is the first thing i would check
Old Nov 16, 2011 | 03:14 PM
i checked my distributer cap and it looked good.and i dont think my fuel pump is priming. how do i check my fuse and my relay?
Old Nov 16, 2011 | 03:30 PM
Wrona's Avatar
check for spark not the distributor cap....
Old Nov 17, 2011 | 08:48 AM
LicensedHustler's Avatar
pull a plug wire out, stick a screw driver in the plug wire and hold the bare metal part of the screw driver 2mm from another bare metal object... See if you are getting spark.
Old Nov 17, 2011 | 11:12 AM
fcm's Avatar
fcm
Old Fart
A much better way is to plug a spark plug into the spark plug lead and ground the plug less chance of shorting out the coil.
So now your saying, "i dont think my fuel pump is priming".
If the fuel pump is working you will hear it if you turn your ign. switch on, [run, not start].
If you do not hear it, you will need to check the PGM-FI Main Relay and/or the powers to it. 94
Old Nov 17, 2011 | 10:46 PM
i checked for spark and im not getting anything. also i pulled my spark plugs out and theres oil inside.
Old Nov 17, 2011 | 11:40 PM
mouab18c1's Avatar
Change your o rings and buy a new ignition coil.
Old Nov 18, 2011 | 04:50 AM
Wrona's Avatar
This is correct
Go to napa and buy a valvecover gasket it fits like oem and is made in Japan ignition coil get brand new never get ignition components used
that747guy
34
Jan 2, 2021 09:27 PM
prelude2.2
Apr 24, 2012 12:23 AM
WanaBeFaster
Nov 13, 2007 06:32 AM
Zion-I
Jan 24, 2007 07:34 AM
