High compression pistons in a b16
I'm not sure why you would want to increase the compression when B16 compression is 11:1. Unless your going for all motor or possibly forced induction in the long haul I would look at lowering the compression to 9:1. As far as changes in valvetrain again if you keeping this all motor or are you looking for my power in the long term? I'm currently at 9:1 static compression with wiseco pistons and eagle rods with all skunk2 valvetrain with ctr cams.
What are your goals?
What do you want to use the car for?
If your just looking for a rebuild on your motor to run NA I would just build a b18/b20 with OEM parts which will hold up to just about all the NA abuse you can throw at it.
