Check engine code 43
Old Nov 15, 2011 | 12:24 PM
hellraiser6's Avatar
Default Check engine code 43
Have a code 43, fuel supply system. Anyone ever run into this issue? Just started getting this code. Normally when the car is at operating temp. Most of the time it is when I am below half a tank. Not sure when the fuel filter has been replaced, so I might do that first.
Old Nov 15, 2011 | 01:00 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Check engine code 43
It has - thousands of times... It really helps to search...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/code-43-bad-mpg-bad-fuel-smell-2989615/
http://www.htarchive.net/showthread.php?t=2982099
This is just the beginning...
Old Nov 15, 2011 | 01:17 PM
Thanks for the point in the right direction. My search pulled many topics not even related.
https://honda-tech.com/forums/showthread.php?t=2989615
Old Nov 15, 2011 | 03:15 PM
rd91sib18c5r's Avatar
I have had this code, swapped the o2 sensor. Or could be your fpr.
Old Nov 15, 2011 | 04:17 PM
I am going to go with the O2 sensor since I have bad piston rings at this time. Still putting the other motor together so that I can swap them out.
dejay2014
Aug 24, 2014 09:16 PM
dirk digler
Jan 25, 2009 04:44 PM
essex
Jul 25, 2005 06:11 AM
TOMSBLUEHONDA23
Apr 23, 2005 04:12 PM
Jockobo
Jul 26, 2003 01:56 PM
