funny idle problems
Old Nov 14, 2011 | 07:14 PM
purplerain11's Avatar
Default funny idle problems
Ive been having this fluctuating idle thing going on with my d16z6. Just runs up to 2000 rpm and drops to 1000. Does it repeatably... It does this with the clutch in or out, only at idle. Anyone have any ideas, i cant seem to figure this one out?
Thanks
Old Nov 15, 2011 | 04:36 PM
Default Re: funny idle problems
I am now getting a CEL sometimes when i start the car and it stalls out and wont start. ANY HELP ANYONE!
Old Nov 15, 2011 | 05:04 PM
bbarbulo's Avatar
there is an FAQ post in the sticky at the top of the forum that deals with all kinds of idle issues. start with that, then get more specific.
Old Nov 15, 2011 | 05:17 PM
civicjunkie17's Avatar
+1
Alot of hondas have idle problems. First place I usually start is air in the cooling system. goodluck
Old Nov 15, 2011 | 05:32 PM
Steezer's Avatar
so the idle rise and drop is either a vacuum leak(important hose loose or you have a bad gasket) or or your IACV (idle air control valve) is going bad or may just need to be cleaned. The Ecu is trying to compensate for lost air so it idles F***ing weird. I havent heard of a car stalling and not starting from this though.
cheak for a vacuum leak or Iacv first.
Edit* If there is air in the cooling system it can cause your temp gauge to go to max. Keep an eye out for that too.
Old Nov 15, 2011 | 06:58 PM
The reason why I said check the coolant first is because coolant runs through the IACV. Even if the IACV is fine if there's air in the coolant it will idle like crap.
Old Nov 15, 2011 | 07:14 PM
Kylehugo's Avatar
IACV!!!
Old Nov 15, 2011 | 07:41 PM
One92Eg6's Avatar
fast idle valve.... it happen to me.... check it
Old Nov 16, 2011 | 05:20 PM
ok ill check into it. Thanks for the info. Any other idea's about the stalling? Happends usually when i turn the car off or stall it and try to start it up again within 5 mins.
It starts up and then runs to 2000 rpm drops and stalls out?
Old Nov 19, 2011 | 05:05 PM
was the IACV that needed attention. As for the stalling i am replacing the main relay. That should do the trick.
Old Nov 24, 2011 | 07:40 PM
Well turns out it wasnt the IAVC..... Got it checked out by a mechanic friend and he says its not dirty and doesnt need cleaning. We did unplug it and the car idled fine.... just didnt start after truning off... so pluged it back in. Still have the surging idle...
Could it need replacing i guess? Any other ideas please anyone!
Old Nov 24, 2011 | 07:50 PM
b20c's Avatar
U need to screw in your fast idle valve on the back bottom of your throttle body it has a plate with two 8mm screws that hold the plate on. Take it off and screw the yello thing all the way in with a very small flathead. Not the iacv its the fast idle valve hope that helps
Old Nov 24, 2011 | 08:00 PM
b20c's Avatar
The dyin sounds like your dizzy coil might be takin a ****. The surge is a dif prob sounds like leave iacv plugged up fix fit valve
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
TearSDMF89dx
Jan 3, 2012 04:31 AM
BrokenRex
Oct 13, 2005 08:25 PM
91SE
Feb 18, 2003 04:35 PM
