code 43 HELP ME PLEASE !!!!
Old Oct 6, 2002 | 10:15 PM
ThatRicerDaniel's Avatar
Default code 43 HELP ME PLEASE !!!!
this code is driving me freakin crazy. i cannot get this thing to clear. its FUEL SUPPLY SYSTEM.. i have a 91 SI with a 91 LS. Some one told me to sand my grounds and i did that . some one told me to change my gas cap and i did that. i change fuel rail. checked all injectors and those rubber gaskets around them.i changed fuel reg and bumped up the pressure. i tried different ECU. also what should the stock pressure be at? thanks !
Old Oct 7, 2002 | 01:30 AM
vtec crx's Avatar
Default Re: code 43 HELP ME PLEASE !!!! (NitrousDreamz)
i have a friend with the same problem,**** sucks huh?
Old Oct 7, 2002 | 02:04 AM
Bseries's Avatar
make sure youir O2 is working.
Old Oct 7, 2002 | 07:14 AM
actually its not.ill fix that today.
Old Oct 7, 2002 | 08:00 AM
EightOhOne's Avatar
mines throwing the same code, i have to mess with it today to see if i cant get rid of it
Old Oct 7, 2002 | 11:46 AM
Aphrodavid's Avatar
Default Re: code 43 HELP ME PLEASE !!!! (EightOhOne)
check my sig for my car. well one day i decided to use a 90 LS ecu unstead of my 91 SI. had more low and mid power but no top end. after the car ran for about 5 mins, i started throwing code 43. car still ran fine for a week. then i decided to go back to my 91 SI ecu. my guess is it has to do with dumping too much fuel.
Tj98520
Mar 28, 2016 12:31 AM
mugenteggy001
Jan 31, 2011 07:40 AM
mugenboi
Nov 2, 2007 05:12 AM
DR. ON POINT
Dec 27, 2002 02:32 PM
