wiring diagram for gsr 95' any have this??
I'm guessing you want the alarm pinouts....
2000 Acura Integra Alarm/Remote Start Info
Starter Black/White Ignition Switch
12V Constant N/A Battery
Ignition Black/Yellow Ignition Switch
Heater Yellow Ignition Switch
Accessory White/Red Ignition Switch
Tach Blue At Coil
Brake Switch Hot N/A Brake Switch
Brake Switch Cold Green/White Brake Switch
Courtesy Lights(-) Green/Red Near Fuse Box
Parking Lights(+) Red/Green Steering Column
Door Lock (-) 3 wire Black/White Left Kick Panel
Door Unlock (-) 3 wire Black/Red Left Kick Panel
Trunk Release (-) Green/Black Left Kick Panel
Power Windows LF Up (+) Red/Yellow Driver's Switch
Power Windows LF Down (+) Red/Blue Driver's Switch
Power Windows RF Up (+) Blue/Yellow Driver's Switch
Power Windows RF Down (+) Blue/Green Driver's Switch
Sunroof Close (+) N/A At Switch
Sunroof Open (+) N/A At Switch
Horn(-) Green/Red
There you go..
-Rage
Tach Blue At Coil
Horn(-) Green/Red
There you go..
-Rage
heres the one for a 95(its a little diff than the 2000):
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/white |- |drivers kick panel *2 |
| POWER UNLOCK|black/red |- |drivers kick panel *2 |
| PARKING LIGHTS +|red/black *3 | |grn plug above fusebox |
| PARKING LIGHTS -|blue/red | |factory alarm (if equipped) |
| HEADLIGHTS|red/wht (low) 12awg|+ |steering column |
| DOOR TRIGGER|lt. green/red *4 |- |drivers kick panel *2 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green |- |*6 |
| HOOD PIN|yellow/red |- |drivers kick panel |
| FCTRY ALARM ARM|factory remote only | | |
|FCTRY ALRM DISARM|factory remote only | | |
| TACHOMETER|blue | |distributor *1 |
| SPEED SENSE|orange | |instrument cluster |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray or blu/grn |- |steering column |
| WIPERS|blue & blu/yel *5 |- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp |
| RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp |
| SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof switch |
| RADIO 12V|white/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA|yellow/green |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/wht | |radio |
Notes:
*1 Also found in a 16 pin white or gray plug to the left of the fusebox. *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch. *3 Also a male blade terminal is available in fuse box. *4 Looks like 14 awg wire but mostly insulation. *5 Use both and diode isolate each. *6 12 pin blue plug on top center of fusebox.
Notes:
AznMTboy
Jun 27, 2005 05:25 PM
