brake problems
Old Nov 14, 2011 | 02:16 PM
rockrig's Avatar
Default brake problems
Hi yall, I have a problem I'm hoping somebody has an answer to. I put rotors and pads on my 1990 civic dx and afterwards I had no pedal, it would go almost all the way to the floor with very little brake pressure, so I bled the lines still no pedal... had a tightish pedal with the car off but nothing with car running. replaced the MC and fully bled the lines and bench bled MC, still same results, was told it could be the booster but after looking at other posts and checking booster according to said posts it doesn't seem to be the booster so I'm lost.. please help
Old Nov 14, 2011 | 04:20 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: brake problems
Have you checked the adjustment of the rear drums? They could be not working or serving of the sort; this is assuming you bled the master cylinder right and there are no leaks, that leaves only a couple possibilities.
A bad brake booster would cause the pedal to be firmer and NOT softer. It's vacuum assist braking, not vaccum operated.
Check the rear brakes and report back - then we will go from there (this is assuming everything else is golden).
Old Nov 14, 2011 | 04:24 PM
lazlong's Avatar
Bleed the living hell out of 'em. They can be stubborn sometimes. Once, I had to bleed my old '90 hatch 10 times.
EDIT: Were the brake cylinders leaking? Or, for that matter, was anything leaking? Is it pulling at one wheel when braking?
Old Nov 14, 2011 | 04:37 PM
rockrig's Avatar
I haven't actually looked at the rear brakes. but I applied the e-brake and tried to move it and it wouldn't move... we have bled the brakes three times already, guess I will do some more tomorrow night.
also there are no leaks... everything is tight
Old Nov 18, 2011 | 05:40 AM
rockrig's Avatar
well, didn't get a chance to look at the brakes will definately be working on it this weekend, will let yall know what happens
Old Nov 18, 2011 | 08:04 AM
DO IT ON ALL FOURS
If your rear brakes aren't working that you can be almost 100% sure that is the problem.
Old Nov 21, 2011 | 02:01 AM
rockrig's Avatar
ok, got to work on brakes yesterday. I found passenger side rear wasn't completely working, adjusted.. better.. then pulled apart fronts and found a gauled sleeve on the top of driver side that wouldn't let the caliper float properly... lubed up both sets of pins and put it back together .. much better,
thanks for the help
Stanceman
Dec 28, 2017 05:41 AM
4DoorCivic1
Jun 4, 2012 08:43 PM
USDM-EK4*
Apr 4, 2008 07:50 PM
JZA70
Nov 14, 2006 11:16 AM
veejay
Jul 24, 2001 09:39 AM
