Flashing seatbelt light on dash
Old Nov 14, 2011 | 07:42 AM
CWBETB's Avatar
Default Flashing seatbelt light on dash
Help! Driving me nuts. I have a 90 Civic hatch. If I start the car with the door closed no seat belt light on the dash. If I open my car door, the seat belt light flashes, I close the door put seat belt on, and it still flashes, I have to start the car back up to get it to clear. I tries disconnecting the seat belt sensor under the seat, but still has same issues. Any idea on this one?
Founds past posts about this with no clear answer
Old Nov 14, 2011 | 03:30 PM
JOE BD-0's Avatar
Default Re: Flashing seatbelt light on dash
Disconnect the door latch sensor wire that is inside the doors....good luck....
Old Nov 14, 2011 | 03:47 PM
CWBETB's Avatar
Checked every fuse, all good...meh
Im thinking it has something to do with the seat buckles on the seat, this started ever since I was sliding the seats back and fourth. Maybe I can get some from Honda and if they dont work just bring them back....
Old Nov 14, 2011 | 04:42 PM
rbwdriven's Avatar
Check you connection up top near the mirror.
That will give you fits.
if you are 90/91.
Old Nov 14, 2011 | 04:47 PM
lazlong's Avatar
Start by checking wires in and around the wire boot in the door hinge area. It looks like a rubber accordion.
Do you have the "auto" seatbelts on the door?
Old Nov 15, 2011 | 02:41 PM
CWBETB's Avatar
No auto seat belts.
The connection on the roof was disconnected long ago for having random fits.
Thanks all keep them coming
Old Nov 15, 2011 | 05:07 PM
rbwdriven's Avatar
Did you check your door lock switch?
Take out ( phillips screw) and sand clean apply contact cleaner the reinstall.
Also check door latch connections.
I'd look at door latch switch first.
Old Nov 16, 2011 | 04:05 AM
CWBETB's Avatar
Door lock connections appear to move free, sprayed wd40 just incase, no luck
Old Nov 16, 2011 | 05:31 PM
lazlong's Avatar
I'm telling ya, look in the wire boot between the door hinges.
Old Nov 29, 2011 | 06:12 AM
CWBETB's Avatar
Did some test last week and dug into it today. I swapped the lower seat belt latches and same issues. I sprayed wd40 in the lock mechanism on the door and it actually fixed it....for 1 day. I tried it again fixed it for 1 day and started up again which is telling me, that the fluid is acting as a electric guide that may be missing somewhere in the latch. I took apart the latch "which is a total PITA btw" and Im going to get a new one, sadly costs 70+ BUCKS! After looking at it "maybe" just unhooking the wire sensor would stop it from blinking, I just hate doing this half assed. Here is the part I am going for #10
Old Nov 29, 2011 | 07:52 PM
crex3's Avatar
my 88crxsi dash light for seatbelt flashes sporadically, sometimes when I
go over a bump... belts are on pillar and not on door. When I wiggle the
belt connection on the side of the driver seat, it finally stops so that is
where I need to check things out. Thanks.
Old Nov 29, 2011 | 08:06 PM
Smokinsax's Avatar
The Boot
I know you said all fuses but did you happen to check the under hood fuses too?
Old Nov 30, 2011 | 07:41 AM
CWBETB's Avatar
Correct, no luck
Old Dec 2, 2011 | 01:27 PM
75MPG@55MPH's Avatar
Both door and seatbelt lights flash on my 90 and I can hear a clicking on and off in the door while driving??
Old Dec 4, 2011 | 04:35 AM
CWBETB's Avatar
Fixed it! It was the door latch. As far as I can tell inside the latch needs metal to metal touching, either mine was worn out or dirty. Im thinking more worn and no longer touching causing the issues. So about $90 to fix and was a total pita. Another option is just to disconnect the sensor within the door, but Im to **** to do it the half assed way
tyrone27
Nov 30, 2018 05:05 AM
ThePizzaMan
12
Jan 22, 2013 09:16 PM
hondad6
Feb 21, 2012 09:37 PM
WindyCity
Jul 6, 2006 12:12 PM
rhetorical
May 16, 2004 06:57 PM
