'99 rotor screws stripped
I was using an impact wrench to remove the rotor screws on the rear wheels. I stripped one screw and the other is close. Is there any way to remove the screws that can be done by a weekend mechanic. Can I remove the wheel hub bearing with the rotor and replace both instead of messing with getting the screw out?
dril the heads of the screw off and dont use an impact gun on screws in the future. get a bit for a ratchet and use that before you screw up those screws, also liquid wrench helps a lot too.
The Toecutter
Jan 13, 2003 02:36 PM
My russian is much better
