how do i change my rotors???
Re: how do i change my rotors??? (SI-racer)
Remove tire, REmove caliper and the 2 screws behind the rotor. Than Remove the two screws in front. (Get a good screw driver, not a calamina one.)
A impact screwdriver works well on the screws that hold the rotors on, you can pick one up at any autoparts store for around 25.00 bucks or so.
Re: how do i change my rotors??? (neof69)
if you can't get those screws undone and you don't want to strip them, use some WD-40. Let it set in there for a couple of minutes, then give it another try. Works wonders.
good luck,
aj
good luck,
aj
after you remove your caliper, hit the old rotor with a rubber mallet, no reason to use an impact screwdriver.. lol thats funny...
just hit it a couple times and the screws will be lose enough to unscrew by hand...
if you use an impact screw driver, youll probably strip the screw!!! and that would suck!
Re: how do i change my rotors??? (96exb20)
SIRacer: here you go
http://www.bseries.net/html/garage/brakes.php
You really should use an impact screwdriver! I had no luck getting mine off with a hammer + screwdriver + WD40.
With the impact, it is cake!
Re: how do i change my rotors??? (Phantom)
impact screwdriver is the best tool for the job imo
I just drilled mine out, took less than 5 min..check it out..http://www.deeperimage.com/forums/sh...=&threadid=461
Re: how do i change my rotors??? (mano77)
I guess some people, like myself, were getting confused. I thought you were talking about the air powered impact wrech.
I would definitely agree in getting an impact driver to do the job. That's what they are for.
good luck,
aj
good luck,
aj
