Classic Hondas All Pre-1988 Hondas.
1986 CRX Si starting problems, please help.
Old Nov 13, 2011 | 10:46 AM
MrZimmy's Avatar
Default 1986 CRX Si starting problems, please help.
Hey everyone,
I've got an 86 CRX Si recently everything on its been running fine, a few days ago it started to get hard to start the engine would turn over but it usually took one or two tries to get it running. I parked it, tried it a few more times and it started up every time, then I let it sit for a few hours while I was at work. Now it won't start, the engine doesn't turn over nothing. The fuses all look good everything looks to be connected fine and the starter was replaced less than a year ago. Any help or ideas would be greatly appreciated.
Old Nov 13, 2011 | 12:27 PM
G. Man's Avatar
Default Re: 1986 CRX Si starting problems, please help.
How's the battery? You can usually have the battery and starter tested at a parts store. If the starter you got was from a parts store it could be bad. The best bet when it comes to starters is to find a local shop to rebuild them. It usually costs half as much as the refurbished starters from the parts store anyhow. Another possibility is the lock cylinder. When it doesn't start, do you get lights in the dash? If you have no power anywhere, I'd bet on lock cylinder or battery. Hope this helps, good luck
Old Nov 14, 2011 | 08:25 AM
Gustav129's Avatar
Are you getting any clicks or any other noises when you try to start it? If not, check the battery terminal, especially the negative....
Old Nov 15, 2011 | 09:47 PM
MrZimmy's Avatar
Thanks for the help guys, it was the starter. I've got a day off tomorrow and will be fixing it then.
t1nwh1sker
10
Jul 5, 2012 09:40 AM
JgranerG
Mar 23, 2010 09:47 PM
mattwarden
Jan 16, 2008 05:52 PM
@.com
Jun 10, 2006 11:14 PM
shaundesjardins
Feb 23, 2004 10:34 AM
