weird shut off issue
So it doesn't matter whether your driving the car down the road or If you just started her up. I can being doing either but no matter what it happens randomly. When I start the car up It will fire up and run then 2 seconds later all the dash lights go out and the car shuts off. I then Turn the key backwards to off position. And try to restart it and it will repeat the same issue again. It will do this a few times on and off randomly then It will just fire up normally. Anyone got some test for me to figure out the culprit. Or just know the answer.
Might sound obvious, but did you check the battery terminals for good contact? Maybe the electrical contact is getting interrupted from vibration or something? Make sure they're tight, and clean.
claud122003
Aug 15, 2011 05:53 AM
bdubnyc
Sep 4, 2008 07:07 PM
amazinspiderman
Jul 20, 2007 01:06 PM
DIYMIKE
Jan 30, 2005 09:39 AM
