Battery Light Comes and Goes w/ Throttle
Old Nov 13, 2011 | 05:39 AM
mississippi_ef's Avatar
Default Battery Light Comes and Goes w/ Throttle
Sounds wierd, but my battery light comes on when I crank the car, and and then when I begin to drive it goes off when I use the the throttle. When I shift gears (let off the gas) it flashes back on.
I've checked my grounds, and they all seem to be intact (3 grounds I believe), and the battery has juice. There's no problem starting the car. Any ideas? The car is a 91 hatch, factory d15b2 w/ dpfi. Thanks.
Old Nov 13, 2011 | 05:42 AM
Old goat's Avatar
Default Re: Battery Light Comes and Goes w/ Throttle
sounds like the alternator is going bad also check your belt tension
Old Nov 13, 2011 | 05:58 AM
Will do, thanks for the suggestion.
Old Nov 13, 2011 | 02:22 PM
swaped-civic-si's Avatar
yeah just had that problem.its the alternator
Old Nov 13, 2011 | 09:56 PM
Bently_Coop's Avatar
Steve at Heart
It is definately your alternator. Sounds like it only works under a load.
Old Nov 13, 2011 | 10:01 PM
91efbluehatch's Avatar
where at in MS are you located??
Old Nov 14, 2011 | 04:14 AM
Tupelo, way North. Thanks for the feedback everyone. Seems I've found my problem.
Old Nov 14, 2011 | 06:05 AM
I'm in biloxi
b16_swap
Mar 30, 2011 06:51 PM
89edcivic
Sep 26, 2009 02:38 PM
EG6[B16A1]
Feb 17, 2005 10:52 PM
fe519
Sep 23, 2003 03:25 AM
Alexnaderkeith
Sep 10, 2003 08:32 AM
