Tps gone wrong
Old Nov 12, 2011 | 01:03 AM
Jae fillz's Avatar
Default Tps gone wrong
I have a 93 hatch with a single cam...car had what seemed like a bad tps...when I bought the sensor and went to put it in I was going to adjust the ohms but it seems that when I'm doing it(I have read the tps install guides like a thousand times) I only get a ever changing ohm reading...I thought I was using the two correct prongs but maybe not...any Info would be great...I'm using a craftsman autoranging multimeter....could the throttle body be bad
Old Nov 12, 2011 | 06:38 PM
hybridmiklo's Avatar
Default Re: Tps gone wrong
your meter shouldn't be on ohms. It should be on voltage. Place the red probe on the signal wire and the black on the ground wire.
Old Nov 13, 2011 | 12:17 AM
Jae fillz's Avatar
I herd about doing it with volts.....what voltage does this need to be set to....and what color wire is considered signal and which is ground...just trying to not **** up again
Old Nov 20, 2011 | 07:46 PM
10psiLsEf2's Avatar
.5 at closed throttle 4.5 at WOT!
Should be set to volts not ohms (resistance)
Back probe the middle wire with a safety pin. touch it with red probe
and put black probe on the battery(ground)
mecca858
Apr 25, 2022 09:12 AM
bmiller17
22
May 19, 2013 05:54 PM
Powered by VTEC
Jan 30, 2008 10:06 AM
n20sol
Dec 17, 2005 10:28 AM
