ignition timing order question
Old Nov 11, 2011 | 05:22 PM
Da9austinRacing's Avatar
Default ignition timing order question
Where should the rotor be pointing when cylinder 1 is tdc and how is the piston order like cylinder 1 is where
Old Nov 11, 2011 | 10:02 PM
mouab18c1's Avatar
Default Re: ignition timing order question
You adjust ignition timing with a timing gun.
Old Nov 12, 2011 | 12:04 AM
mark@silbernage's Avatar
Trying to figure out where the spark plug wires go on a cap/rotor/wire replacement?
Driver's side is cyl#1, passenger #4..
Mark
Old Nov 12, 2011 | 04:32 AM
TheRealTegger's Avatar
Looking at the distributor while standing at the passenger fender, and using a clock-face as a reference... The #1 cylinder is at the 8:00 position. #3 is at 10:00, #4 is at 2:00, and #2 is at 4:00.
Old Nov 13, 2011 | 04:44 PM
hondalike's Avatar
http://www.team-integra.net/forum/11...ing-order.html
bryse82
Feb 9, 2009 07:40 PM
dopefeen
Apr 25, 2007 04:59 PM
kpringcivic
Oct 23, 2005 11:36 AM
Attoir
Mar 18, 2004 01:25 PM
