Lsv no spark on ej1
95 civic ex coupe. Ls vtec built from ground up the right way. Changed dizzy, plugs, and plug wires. I checked everything like 5 times I even checked for power from the harness on the dizzy plug and nothing but when I unhook the engine harness and check I get power, I changed the engine harness also and ecu but still no spark. I'm getting fuel and grounds are clean and hooked up, and fuses are good, also no CELs.I need ideas because I searched and tried all the basic things.
I don't know how I'm getting spark now but I have and that's weird. But I bought a compression test kit, took out all the spark plugs and cut the fuel and cranked the motor. It wouldn't build compression across the board wet or dry.
realmc
Aug 25, 2005 09:21 PM
