SKUNK2 PRO 1 Cams Ticking like a bomb!
Old Nov 10, 2011 | 09:45 PM
Mike Lowwryyy's Avatar
Default SKUNK2 PRO 1 Cams Ticking like a bomb!
So I installed the Pro 1 cams and adjusted the valve lash as recommended and this thing ticks like crazy. They weren't degreed and the motor is a fresh build with new LMAs. I used Skunks quick setting and the car runs well, idles good and pulls -20 hg of vacuum (idle)
I got Ferrea Valve train but I had ITR cams ion before and they didnt tik this loud...
Any of you guys with race cars have a smooth and quiet engine or is this a little far fetched? I hope not, cause my car sounds like a Diesel!!!
Old Nov 10, 2011 | 10:03 PM
hksitr's Avatar
Default Re: SKUNK2 PRO 1 Cams Ticking like a bomb!
sounds like your got the valve lash wrong or valve float issue
Old Nov 10, 2011 | 10:23 PM
TheShodan's Avatar
Moderator
Valve lash is off, and the cams MUST be degreed in order to work properly.
Old Nov 10, 2011 | 11:48 PM
wolve's Avatar
x2
i was going to say LMA's next but then i saw they're fresh
nothing binding in the valvetrain?
but offcourse they're going to be louder then your itr's, have you compared the primaries of the ITR/PRO1 side by side yet?
ramp angle is quite agressive
Old Nov 11, 2011 | 12:01 AM
I was so anxious to put these in, didnt really do a side by side comparison... And usually I like to admire parts before putting them in, Lol.
Technically speaking though... it shouldnt need to be degreed for valve lash to be right. I mean valve lash is just clearance right?
Old Nov 11, 2011 | 12:07 AM
V-SPEC 1's Avatar
Can you record an audio and post it here so we all can listen to it?
Old Nov 11, 2011 | 12:22 AM
boooosted's Avatar
x2 on what it sounds like. Make a recording
Old Nov 11, 2011 | 12:31 AM
wolve's Avatar
side by side the primaries are like david and goliath
degreeing has no influence on valvelash...
degreeing has an influence on things hitting eachother tough
Old Nov 11, 2011 | 12:36 AM
For sure, but it'll take a few days. I took the liberty of relocating the stock ignitor to inside the cabin so once that is done, Ill video the start up.
Hey Wolve, you run the Pro 1? How noisy are they in general?
Old Nov 14, 2011 | 05:01 AM
kyden's Avatar
sounds like your lash is off. my car is a bit ticky on pro1s, but nothing crazy.
Old Nov 14, 2011 | 05:09 AM
Honda Bull's Avatar
How did you set the lash? Sure you did it on the correct cylinders?
p.s. Love the user name. I can hear Martin Lawrence saying that in my head as I type this. LOL Great movie.
Old Nov 14, 2011 | 06:28 AM
m3tech95's Avatar
take a short video of the car on startup....threads like these help people out even years after people stop posting in them...i can vouch for that
Old Nov 14, 2011 | 06:45 AM
mayfly's Avatar
what cam gears r u running?
Old Nov 14, 2011 | 07:10 AM
TheShodan's Avatar
Moderator
The car's idle should sound like this. (This engine has the Skunk2 valvetrain, Cams, Cam gears and Ferrea valves)
http://www.youtube.com/watch?v=Q0yMdVOLkBM&NR=1
They need to be properly degreed in order to operate properly. They are not like the tuner series. Cam Gears are a necessity when running these cam shafts.
Old Nov 14, 2011 | 09:44 AM
ugly88si's Avatar
i would pull the cams out and check to see if your center rockers are getting scuffed up .i ran pro 2s on itr lmas and they had so much lift they were bottoming out and digging into the rockers.i think the lift on both cams are pretty close
Old Nov 14, 2011 | 12:35 PM
The sweed's Avatar
Check the clearance between the camlobes and the oilbridge above it..
Old Nov 14, 2011 | 12:46 PM
cibao2ner's Avatar
i have a similar problem with my new built lsvtec with buddy club spec 4...supertech springs..ticks really loud...i did valve lash but havent recheck it since the engine was started...ticks loud compare to a friend with a similar build on crower stage 3 cams..
Old Nov 15, 2011 | 07:36 AM
It was set according to skunk2 specs... I had the cam printout sheet next to me when I did it. I cant remember what they are now, Lol... Im running skunk2 cam gears and yes they were done per cylinder and then I rotated the crank to the next.
Shodan... mine does not sound like yours in the video at all, lol.
I just have to install the Mallory and the ignitor in the cabin and hopefully I can start up this weekend...
I have a quick question about the ITR cams cause Im considering throwing those back on... Since the ITR is an OEM cam, do you have to lock VTEC to degree it or can you do it on the primaries?
Old Nov 15, 2011 | 07:57 AM
kyden's Avatar
you don't need to degree oem cams.
Old Nov 15, 2011 | 08:10 AM
Reason I ask is because I dont know how much the deck height has changed with the build. I just wanted to double check for a peace of mind...
Old Nov 15, 2011 | 08:22 AM
TheShodan's Avatar
Moderator
At the risk of sounding BOLD, that's a problem if they don't sound like that. Wait the first 15 seconds, and you'll get an idea of how they should sound. That's even been verified by SKunk2 themselves that the measurements were correct.
Here's what I went by.
We have to, of course, lock the VTEC rocker so the correct cam lobe can be degreed in.
http://www.youtube.com/watch?v=cs936Mm4Bps
For those that need to know the Skunk2 Pro 1 settings and protocols for the valvetrain, see below.
http://www.skunk2.com/installation/305-05-5140.pdf
According to Brian, When degreeing the cams Valvelash needs to be at 0.
Pro Series Springs:
60lbs closed seat pressure
Install Height - 1 inch @ 320
210 lbs pressure Open @ .5 inch lift
Coil bind - Height 720 @ 600 Lift
Old Nov 15, 2011 | 08:54 AM
kyden's Avatar
double check what? you have alignment holes in the cams for the belt, the tensioner takes up the slack. done.
i'm not sure why you threw the pro1s in without degreeing. the quick settings are for an untouched block and head. mine ended up at +2 on each so the quick settings would have been way off.
Old Nov 15, 2011 | 01:59 PM
TheShodan's Avatar
Moderator
Not to mention quick settings are for the tuner series. Not the Pro 1s
Old Nov 16, 2011 | 07:48 AM
Just trying to understand here... But since the length of the timing belt is constant, when deck height changes, cam timing is retarded... even with stock cams, no?
Old Nov 16, 2011 | 08:00 AM
TheShodan's Avatar
Moderator
Yes, but you still need cam gears to do those adjustments
