1991 crx problemmm
Old Nov 10, 2011 | 05:55 AM
fg2vtek's Avatar
Default 1991 crx problemmm
got a 91 crx base auto with 136k 100% stock. just recently experienced really bad shaking @55mph and above, drives perfectly fine below 55. def coming from under the hood steering wheel doesnt shake, feels like maybe fuel cut out or maybe mounts?
Also one of my spark plugs is filling up with oil. i pull out the wire and its full of oil. rest are dry just recently changed all the seals in the head.
please advise to both problems! thanks
Old Nov 10, 2011 | 06:54 AM
tyvtec23's Avatar
Default Re: 1991 crx problemmm
the shaking could be a number of things, check tie rods, steering, check axles and tires, also the seals might of went bad if u didnt put them in correctly i had the same problem with my car, take the valve cover off and recheck everything
Old Nov 10, 2011 | 07:09 AM
Dioxine's Avatar
Oil on top to the spark plug wires will be your spark plug ring seals on the valve cover.
Old Nov 10, 2011 | 09:11 AM
fg2vtek's Avatar
i have new tie rods and axles..its the motor that is shaking feels like the car is getting fuel cut out as soon as i hit 55 so the motor is bucking. under 55 drives like a dream it also does it for a couple mins when i start my car when its been sitting. put all new seals cuz thats what i thought it as before i changed them due to getting oil in the spark plugs.
Old Nov 10, 2011 | 12:49 PM
Dioxine's Avatar
How does the motor do under load at high rpms. Could be a clogged fuel filter.
Old Nov 10, 2011 | 02:48 PM
fg2vtek's Avatar
That may be it..ima try it.
_EF9
Nov 9, 2014 04:20 PM
PROJECT 91
Aug 14, 2008 08:59 PM
radicaled434
Jun 10, 2008 03:51 PM
copmagnet
Nov 12, 2004 10:01 AM
7rrivera7
Mar 23, 2003 09:25 AM
