Intermediate shaft bearing replacement
Old Nov 9, 2011 | 05:43 PM
ByonSho's Avatar
Default Intermediate shaft bearing replacement
So searched but couldn't find info for this. Can the bearing go bad? I have a loud humming coming from the front louder at high speeds. I thought it was a hub bearing but when I jacked the car up the axle moved at the point where they connect. (axle and intermediate shaft) so I don't think that should happen. Any thoughts?
Old Nov 9, 2011 | 09:12 PM
ByonSho's Avatar
Default Re: Intermediate shaft bearing replacement
71 views and no one knows. Ok well it also stops making noise when I'm turning left.
Old Nov 10, 2011 | 03:24 AM
hondamark35's Avatar
that still sounds like a hub bearing. i have similar symptoms with my wife's accord. only with hers the noise gets worse going around a right hand curve.
what's likely going on is that one of the raceways (in your case inboard on the passenger side or outboard on the drivers side) has some pitting or other damage. when the weight of the car shifts turning left more load is transfered to the opposite, ok raceway so the noise stops.
you didn't mention which year model you have but either way it's not a terrible job replaceing the hub bearing if you have a good set of tools and access to a press.
Old Nov 10, 2011 | 05:16 AM
ByonSho's Avatar
O sorry it's a 94 ex manual. I'm not familiar with the term raceway as a part reference. I replaced the passenger side hub bearing and it still does it. I feuds I'll pull the drivers Friday and see what happens.
Thanks
Old Nov 10, 2011 | 08:42 AM
Thanks
can you tell which side the noise is comming from?
the raceway is the polished groove inside the bearing that the ***** ride in.
Old Nov 10, 2011 | 03:47 PM
ByonSho's Avatar
I can't really tell which side. When I bought the car a year ago the passenger hub was loose. So I figured it was the bad one. There cheap to replace so I'll do it tomorrow. Thanks for the info. Nice to be working on cars for 19 years and still learn something new.
Old Nov 16, 2011 | 02:19 PM
ByonSho's Avatar
Thanks, swapped out the drivers side hub bearing and that fixed it. No more noise!
Thanks
Old Nov 17, 2011 | 03:18 AM
Thanks
great!
tobytigger
Jan 11, 2014 01:41 PM
thaovang09
Nov 27, 2010 01:37 PM
MNMike
Nov 11, 2009 08:54 AM
steve931
Dec 24, 2007 09:06 PM
