bleeding clutch fluid
Old Nov 9, 2011 | 04:17 PM
rpmraper's Avatar
Icon6 bleeding clutch fluid
i have air in my brake lines, dose that meen i aslo have air in my clutch lines aswell? its a 95 civic si hatch btw. also i seafoamed it using the brake booster hose, and when i checked the brake fluid it was almost empty..where did it go? lol
Old Nov 9, 2011 | 04:26 PM
grumblemarc's Avatar
The Grumpiest
Default Re: bleeding clutch fluid
What? Do you think they are connected somehow?
Question, did you check the fluid level BEFORE you Seafoamed it? It should not have affected your brake fluid levels.
Old Nov 10, 2011 | 03:02 AM
Turpid Porpoise's Avatar
Please work on your spelling, proper English is greatly appreciated when trying to solve other people's problems.
How do you know you have air in your brake lines?
No it would not mean you have air in your clutch line as well.
We don't know where your brake fluid went, I would recommend adding more, bleeding your brakes and then driving a short distance and coming back to check for leaks.
Old Nov 10, 2011 | 05:59 AM
rpmraper's Avatar
sorry on the spelling i am disabled.. so bare with me... the po i go got the car from said the " brake block" was leaking and he needed to replace it, i said wtf is a brake block and he replied the thing that turns 2 lines into 4.. im assuming that he did not bleed all the air from the system.. i checked my fluid before i put the seafoam in, then checked it after i connected the booster back. and it was gone.. no clue why or how for that matter.. i put more in and its doing ok just curious as to where it could have gone?
Old Nov 10, 2011 | 06:02 AM
rpmraper's Avatar
i guess the po ment the proportioning valve... i have to pump it to stop..and the proportioning valve looks new and dose not leak ..
Old Nov 10, 2011 | 06:11 AM
The Grumpiest
If it isn't going anywhere NOW then stop sweating it. It probably just needed topping off.
Old Nov 10, 2011 | 08:08 AM
Considering what you just described he must have replaced the Proportioning valve like you said. If your brake fluid level is stable you are most likely fine like grumblemarc said.
With all that being said it seems like you need to bleed your brake system. Not hard to do but typically you need a friend to help.
Old Nov 10, 2011 | 04:03 PM
rpmraper's Avatar
i heard it takes two, my father inlaw is helping in the am, what else are you supposed to do when your a retired air force major? lol
globy123
Sep 27, 2009 05:32 PM
StolenTeg
Sep 5, 2006 05:05 PM
Understeer
Nov 30, 2003 10:28 AM
gingboy
Jul 11, 2001 05:01 PM
