turbo or supercharger on a H22A fully built click for specs on motor
I have 2.2l H22a4 head w/super tech valve train an the works... Bisimoto 2.4 cams an cam gears and its port an polished w/a H22a block w/JE pistons 9:1 compression. eagle rods polished an balanced crank. an yes the block is sleeved. an the transmission has a new blox LSD my goal is to run high 9s ( like 9.75's to 10.4's ) an all this would go in a 2000 BB6. (i don't have to be in the 9's but it would be very sweet) what kind of turbo or supercharger would i need to look into also what type of ECU, axles/clutch kit, injectors an how heavy of a flywheel...???? (would i need 680hp or 850hp) any tip would help (any but a smart a$$ answer)
Thank you...
Thank you...
awfully good start to what can be a good motor. I'd go turbo you kinda are limited when you go supercharger...and like ESP said it'll prob be 11's maybe 10's these ludes aren't easy to put in the 9 sec category.
well considering you have low compression pistons already and the stock H22 came with 10.5:1 compression plus its already sleeved id go with a turbo... the only supercharger that i know made for the H22 in a BB6 is Jackson racing and vortech and they only put out 75hp to my knowledge... if you wanna run 9's thats going to take A LOT of $$$ and dedication... the 5th gen preludes are already over 3k lbs so in order to drop the weight youll have to go full fiberglass body and plexi windows...
Drifter6508
Nov 16, 2011 01:30 PM
Drifter6508
Engine Management and Tuning
Nov 9, 2011 04:34 PM
Drifter6508
Nov 9, 2011 03:58 PM
