YCU Built/Tuned Stock Sleeve Built LS 422/309
Old Nov 9, 2011 | 09:57 AM
Gold DA9's Avatar
Default YCU Built/Tuned Stock Sleeve Built LS 422/309
The car was just recently finished last week and tuned by Arthur Valenti @ his shop: YCU Dyno Tuning Specialist in York, PA. I witnessed the car make 80whp while staying at 13psi(wastegate pressure). The goal was to reach 400whp with out maxing the duty cycle of the injectors. It was reached and passed by 22whp @ 14.5psi. The next day both axles snapped at the knuckles while my friend was making a pull(He has a stock LS trans with a Quaife LSD)
Engine Details:
Stock Sleeve 81.5mm
Block Guard
Eagle Rods
Wiseco Piston(9.2:1 compression)
King Bearings
Cometic Head Gasket Stock Thickness
Port and Polished Head
Web Camshafts Regrind 115
Supertech Springs and Retainers
Supertech OS .5mm Intake and Exhaust Valves
Skunk2 Intake Manifold
Stock Throttle Body
3 Bar Map Sensor
Fuel Details:
FIC 775cc
Walbro 255hp intank
E85 from the pump
Turbo Setup:
Inline Pro Turbo Manifold
Turbonetics Evolution 38mm Wastegate
Synapse BOV
Ebay 57 Trim Turbo
Ebay Intercooler
2.5" Custom Tig Welded Piping
3" downpipe to 3" straight exhaust
Here are some pics of the graph, setup, one of the broken axles. Will post videos once they are uploaded to youtube.
Old Nov 9, 2011 | 10:02 AM
Gold DA9's Avatar
Default Re: YCU Built/Tuned Stock Sleeve Built LS 422/309
I forgot to mention that this was done on a MD-500 Mustang Dyno
Old Nov 9, 2011 | 11:23 AM
B20vEf9's Avatar
The car made stupid power on 14.5 psi lol
Old Nov 9, 2011 | 12:04 PM
YC Underground's Avatar
Most of this was due to the head work done in combination with the web cam. Setup still lacks other parts that will be upgraded later on for more boost.
Old Nov 9, 2011 | 12:17 PM
92frostwhtdb2's Avatar
Pretty simple setup, good numbers for psi.any vids of this setup
Old Nov 9, 2011 | 12:49 PM
LightningTeg's Avatar
Community Builder
An ebay 57 trim on 15 psi making 420 on an LS?
Old Nov 9, 2011 | 01:03 PM
B20vEf9's Avatar
Yes that's what it says...
See my thread I only made 355whp with my built b16 setup on this dyno on 17 psi, and I've walked away from a 600cc sport bike on the highway.
Just saying.
BTW it's 14.5 psi and 422whp lol
Old Nov 9, 2011 | 01:15 PM
Yes there video hopefully I can have them up
Old Nov 9, 2011 | 01:24 PM
lsturbo33's Avatar
Those are impressive numbers for your setup.
Old Nov 9, 2011 | 01:30 PM
B20vEf9's Avatar
Going to upload video elsewhere
Community Builder
Just saying.
A b16 and an LS are 2 completely different animals.
Cam specs?
Old Nov 9, 2011 | 01:32 PM
B20vEf9's Avatar
Well your response made it seem like you are going to call BS or something lol
Old Nov 9, 2011 | 02:08 PM
B20vEf9's Avatar
http://www.youtube.com/watch?v=Yrhjj...ature=youtu.be
Old Nov 9, 2011 | 02:19 PM
Glove's Avatar
because its on E85,
wouldnt get near that with 93
Cam spec can be found on web cam site, just look for regrind 115.
Old Nov 9, 2011 | 02:25 PM
B20vEf9's Avatar
Originally Posted by Glove
because its on E85,
I know why it made good power, and I'd be willing to bet it'd still do upper 300s on 93.
You act like e85 just gave it 100whp.
Old Nov 9, 2011 | 02:27 PM
B20vEf9's Avatar
http://www.webcamshafts.com/pages/au...31_000568.html
Old Nov 9, 2011 | 03:21 PM
Gold DA9's Avatar
I forgot to mention the car is revving to 7800
Old Nov 9, 2011 | 04:14 PM
EF ridin 4 Life's Avatar
nice numbers...! For 14 psi even if you had a vtec head those would still great numbers for such low boost.
hows the ls tranny with the boost..? I normally like to run a gsr tranny but i came across a ls tranny cheap so im gona run that on my new setup and was hoping it would be better for dd car and traction on the street. Also your really making me consider not putting on my gsr head on my ls block! Good work guys.
Old Nov 9, 2011 | 05:26 PM
deeweezy187's Avatar
damm nice numbers im going to be runnning the jg303 cams on my b18b1 pretty soon hope i get similar numbers as you.
Old Nov 9, 2011 | 06:02 PM
Bseriescivic5's Avatar
Would love to see the timing map you have on this..... Great numbers.
Old Nov 10, 2011 | 12:26 AM
because its on E85,
Wow this is your response due to your ignorance. Man some of you kids have a lot to learn about tuning and a proper setup. Tuning is a science / art, that must be understood with every setup tuned. E85, 93 octane or whatever type of fuel needed to make combustion to create rotational force, is a science that most won't ever understand why or how come what they do when it comes to tuning. So yes I would have made these number with pump gas depending on the scientific measure of the proper chemical elements to create proper power. Take it how you want, it is what it is.
Old Nov 10, 2011 | 12:30 AM
PM me, I'll be willing to show you log and the map for educational gain and help explain based on the car setup and condition for such power if willing to learn.
Old Nov 10, 2011 | 03:58 AM
Turbo-LS's Avatar
PM'd im interested as well
Old Nov 10, 2011 | 04:08 AM
ZMX's Avatar
ZMX
That post had no coherent point.
All you did was talk insult him, say "tuning is a science," and that burning fuels create rotational force.
The fact remains: Yes, you might have been able to stretch that engine to reach 422whp on pump gas. But, whatever the power limit for pump gas is, E85 has a higher one.
Also, if the engine would run fine on pump gas, why it even using E85?
