Garrett Releases GTX3576R Turbo
I'm pretty excited about it as I think a 35R might be a little more lag than I am looking for on my 2.0L, but I'm getting complacent with the GT3076R I have right now.
http://www.enginebasics.com/Advanced...0GTX3576R.html
Possibly. I think the GTX3076R would be a better match for the use. Considering that the 11 blade single bladed design needs more rotational speed than the standard, and its 3mm smaller in the inducer and over 6mm smaller in the exducer than the standard cast model, using the same turbine wheel, structure and shaft, it will be interesting to see. This is similar to what Forced Performance did about 5 years ago to their HTA GT35R.
Why would you suggest the GTX3076R knowing that it is just TO MUCH FLOW for that poor little 30R turbine?
Because I don't use the dyno to show its use for it. I guess I'm old. i only use the circuit track to run the GTX3076R, and don't rely much on dyno charts when it comes to smaller turbochargers unless there is a boost pressure/rpm graph to compare to (especially those less than 65lbs/min). I admit, the compressor wheel is a bit on the large side for the turbine (almost the same mistake they made with the GT3040R), but its still usable for circuit events, as it was never intended to be a Super Powermaker.
Getting the best of two worlds of response AND BIG POWER is almost impossible, as both Garrett and BW EFR have tried, EFR being slightly more successful in this particular race. But I think that the GTX3076R is about as good as Garrett has for this particular use. I only see the newer GTX3576R as being something to compete with the 2.5 litre sector with good flowing head(s) on certain platforms. Just like the FP HTA.
The difference in boost threshold between the GTX3076 and GTX3071 is almost nothing. Also, the GTX3076 makes GT35 power.
http://forums.nasioc.com/forums/show....php?t=2110277
Sometimes choosing a proper compressor is not always about peak flow in relation to the turbine... Especially in some circuit racing applications, when air temps, heat, engine bay temps, and continuous operation will determine the choice of compressor.
For example, although a GTX3071R may seem to be an appropriate turbo when we speak of sizing the compressor vs overall power for most street driving and drag racing, but it depends on boost pressure and lbs/min to determine where the compressor will be running on the compressor map in its efficiency range.
Some engines (like most single cams) require sh*t loads of boost to make power, especially those with smaller cams and stock head... In this case, running a GTX3076R will result in more lag, but net you much better efficiency and landing on a much better spot on the map.
On a circuit condition, this also mean lower IAT's, lesser chance of heatsoaking the intercooler, or possibly get away with using a smaller intercooler to have other benefits like more airflow to the radiator, more room for oil coolers and such, less openings at the front bumper for better aero, or even gain a bit of transient response from a smaller intercooler.
Just thought I bring up these few things to look at turbo sizing in a different perspective beside dyno and street/drag racing
Its almost too hard to believe, but you tested it. Can you share the dyno plots please? Or the data logs if you never dyno'd it?
JR
It's too new for anyone to test yet.. Patient's Muckman. give it about 3 months for full release. It didn't come out until last week
. And i'm sorry, but 9psi is not a test. That's not even remotely close to its boost pressure effective range of 15-33psi of pressure
Hey when does this new Turbo come out? I wanna do more research on it cuz I might do a Turbo motor later. Ir wonder what will the difference between the older and the newer 3076r will be. Will it spool faster? I want a Turbo setup for daily driving/street that spools fast but still makes power all the way up. Useable power Is what I'd Like so I could still do dig runs and keep using my itr trans. Thanks for your advice!
Originally Posted by Engine Basics
Full-race is one company that loves to show back to back gains of mismatched turbo’s to talk about how wonderful a turbo is. Just recently they showed a test of an EFR turbo vs a GT35R. Why would you be comparing Borg Warners newest turbo technology against a turbo Garrett brought to the market over 14 years ago back in the late 90’s. Please don’t fall for this trickery
Yes, there are about 5-7 EFR configuration turbos that have comparable Garretts to match. the 7670 and 5876s are just examples. You can find the full EFR lineup on Full-Race's website
