My 98 Coupe build thread
Old Nov 8, 2011 | 02:50 PM
nealnanoHX's Avatar
Default My 98 Coupe build thread
I figured I would share my 98 Civic Hx coupe. I bought it about 3 years ago from a friend for $1000 bone stock. I knew right away that I wanted to modify it. It started out with a CAI and axle back exhaust. After doing some research I decided that the D16Y5 was not a motor that I wanted to work with but what to swap in. My answer came when I found a 99 B18B1 nearly complete swap at my uncles shop for $800. After about 6 months of parts gathering the D16 was pulled and the B18 was swapped in with working AC, PS and fully OBD2 compatible. A few months later a 4-2-1 header, 2.5 inch exhaust and Hondata S100 went on the car with a result of 133whp and 127lbft. After a while I started thinking about making more power and the decision to go Vtec was made. I sourced a B16 head had it rebuilt and 3 angle valve job done. After the head swap it was back to the dyno for a retune resulting in 161whp and 125lbft. This is where the car is at now. No for some pics
Stock motor
How the Civic looked stock
B18B1 waiting to in its new home
swapped
dropped
On the dyno
results
Vtec
the headless honda
and back to the dyno again
quick dyno vid
Ls Vtec results
Here is what she looks like today
with my del sol (now sold)
Future plans are to boost the stock block with a goal of 250-300whp are currently in motion.
Mod list
99 B18B1 with ARP rod bolts
B16 head stock rebuilt with 3 angle valve job
AEM CAI
Custom ground wire kit
Hondata S100 tuned by Xact Dyno Tempe AZ
Ceramic 4-2-1 header
2.5" cat back
Sportline springs
GR2 Struts
99 Si rear sway bar
Rear disc conversion
Skunk2 rear strut bar
Ebay front strut bar
Solid trailing arm bushings
JDM Sport upper control arms
Blox rear camber kit
Modified oil catch can for crank case vent
Old Nov 8, 2011 | 04:59 PM
furious94ls's Avatar
Default Re: My 98 Coupe build thread
Very nice, good progress.
Old Nov 8, 2011 | 06:04 PM
apexi_rsx's Avatar
looks like your on the right track and done your research. id recommend ARP head studs and a s300 for tuning the boosted motor. Goodluck! looks good
Old Nov 8, 2011 | 06:39 PM
98civdx's Avatar
Master Detailer
I like the sleeper look. But, for the love of god re size those pic's. Those things are huge. lol
Old Nov 8, 2011 | 07:16 PM
540dude's Avatar
nice man, where are you located?
I'm in north phx
Old Nov 8, 2011 | 07:29 PM
Zanzapod's Avatar
i agree you could seriously hustle some people like that haha nice
Old Nov 8, 2011 | 09:31 PM
Duzercivic97's Avatar
i like that. your car look good...lol you're lucky you have a si. i have a 97 civic DX 2d coupe. i still have to work on the front body (just need to repair body thats it) and i am thinking about getting a jobs. so i can save money up to 5,000 or 6,500 bucks so i can work on my car all way. hehe
Old Nov 9, 2011 | 05:22 AM
nealnanoHX's Avatar
Thanks been building cars for a while now but this is my first real Honda project. The built block will get ARP head studs stock block is running GSR head bolts. The S300 was out of my budget but would have been nice for the data logging and multi boost maps but oh well, may be when it ends up becomes a track car.
Old Nov 9, 2011 | 05:25 AM
nealnanoHX's Avatar
I'm in north phx
Mesa. And no I am not on AZHT any more. Those guys are total morons for the most part.
Old Nov 9, 2011 | 05:28 AM
nealnanoHX's Avatar
Yeah I have no plans soon to fix the paint and body keepin it sleeper.
Thanks
Not an Si its a 98 Hx but I have semi converted it to a Si with DOHC Vtec and rear disc brakes. Wanted to hint at what could be under the hood but did not DOHC Vtec all over the car either.
Old Nov 9, 2011 | 06:01 AM
kyden's Avatar
nice progress, but lose the si badge. that is lame.
Old Nov 9, 2011 | 06:35 AM
StreetsideStig's Avatar
^I have to agree. If it's not an Si, it's not an Si.
HOWEVER, the rest of the car looks awesome. Thank you for knowing what you're doing. Most jobs like this are criss-crossed with loose wires melting all over the place, but your bay looks very clean. Great work!
Old Nov 9, 2011 | 09:40 AM
nealnanoHX's Avatar
^ Yeah I dont see how people can mess up wiring that bad. It is pretty simple. I used a 98 Dx harness when I did my swap and it all plugged right in except a few plugs that needed to be changed. I get the clean engine bay comment a lot, thank you my goal was to keep it looking like a the motor can in it stock. And I like my Si badge, it is a mini Si clone with a larger block. Still need the Si seats and cluster though. I had thought about putting a Hx badge back on it to mess with people.
Old Nov 9, 2011 | 11:05 AM
Smarg's Avatar
This says it all.
Let us know how she goes after the turbo!
Old Nov 11, 2011 | 02:38 PM
nealnanoHX's Avatar
^ will keep the thread updated as the turbo kit comes together. It will be a slow build. I added my Auto Meter fuel pressure gauge to my AEM fuel rail today. Yeah! And ordered my waste gate.
Deadpool98
Mar 4, 2019 06:31 AM
Magicmo413
227
May 25, 2014 06:23 AM
tangou
Jan 21, 2007 04:46 AM
deviltodomestics
Oct 19, 2004 01:19 PM
