Crushed intercooler, look and tell me about it
Old Nov 8, 2011 | 11:47 AM
MoreCowbell's Avatar
Default Crushed intercooler, look and tell me about it
Will this hinder performance?
Old Nov 8, 2011 | 12:03 PM
kbouchard1092's Avatar
Default Re: Crushed intercooler, look and tell me about it
my hypothesis, no it wont affect performance enough to notice it....However i would do a pressure test. if its leaking then that is a different story.
Old Nov 8, 2011 | 12:06 PM
MRGRIM's Avatar
R.I.P. Mark
No
not at all
its only the outer case ( just put a long steel bar across the top and use a bollt to pull it back straight..
the wide stripes are what you need to worry about and the end tanks
also do a pressure test if your concerned about it
Hope this helps
Cheers
MrGrim
Old Nov 8, 2011 | 04:44 PM
NotAJDMFanBoy's Avatar
Yeah, it's only the outter case, not where air is actually flowing. I wouldn't worry about pulling it back, just stick some washers inbetween it and your mount to keep it all straight.
Pressure test and fix any leaks with JB Weld.
Old Nov 8, 2011 | 04:50 PM
kaiba's Avatar
It's broken and you should sell it to me. I'll give you $2.
Old Nov 8, 2011 | 04:53 PM
LocoJoe's Avatar
Not broken but be careful, that looks like a tube and fin design which are very easy to bend the fins and screw it all up
Old Nov 8, 2011 | 06:06 PM
sweetfwdthunder's Avatar
Mine was shipped like that to me from Synapse. I was pissed, and its irritating to look at, but it works fine!
Old Nov 8, 2011 | 10:14 PM
h2.4's Avatar
its bar style. that's not even a pressurized vane. it's ok. but double by pressure checking to be 100% sure.
Old Nov 9, 2011 | 05:17 AM
dacowgod's Avatar
Same way as mine was delievered... They offered to replace it..but I was too lazy...You don't really notice it on my car w/ the bumper cover on anyways..
Old Nov 9, 2011 | 05:26 AM
ownedevo10's Avatar
Should be fine but make sure you do a pressure test to make sure its not leaking from the weld...
Old Nov 9, 2011 | 03:42 PM
nealnanoHX's Avatar
The bend wont hurt anything but the size may.
Old Nov 10, 2011 | 07:51 AM
EK-SirVenom's Avatar
lol looking for cheap parts
Old Nov 10, 2011 | 11:27 AM
Thanks for the info guys!
Old Nov 11, 2011 | 04:45 AM
I was in iraq when I ordered mine so it would've been a long painful process to get it exchanged. I just hoped for the best lol.
Old Nov 11, 2011 | 06:45 AM
Flexer's Avatar
That intercooler core looks like CRAP! It is not dense at all. You should see twice the fins in there to dissipate the heat. I would guess you got this off ebay?
Old Nov 11, 2011 | 07:33 AM
LocoJoe's Avatar
EMUSA
twinturboz161
Welding / Fabrication
Nov 13, 2010 09:36 AM
B16Civic93
May 18, 2005 07:43 AM
iwouldHITit
Jan 20, 2003 06:50 AM
DSF
Apr 22, 2002 03:39 AM
