idling high and then low
Old Nov 8, 2011 | 09:33 AM
wvubeerman's Avatar
Default idling high and then low
Check engine light came on in my .2000 Honda civic ex today. I am going to try to clean the iacv from the research I have done this might fix the problem. My issue is use carb. Cleaner is fine right? Also, going to check the codes and link those on here, what I have been searching for is a picture or where this is located. Sorry it is the finacees car and I am gettng ahead of the game have not looked for it yet, but wanted to get some answers before I go attend to yet another problem with this car. Need it to last till July and then new car here we come. I would like to try and avoid taking this in.......also, don't know if this matters had a new timing belt and pump put in this past summer.
Old Nov 8, 2011 | 09:38 AM
datruzz's Avatar
Default Re: idling high and then low
My b20 is idling at 2000 rpm it was idling at 1500 and my distrubuter is in advance and it was running pretty i touch and put the distributor back in advance and is doing like a 2 step (well my ecu chipped and is 2 step) i want to know if i need new distrubuter
Old Nov 8, 2011 | 11:17 AM
UniqueX707's Avatar
From my recent problem of my IACV I clean it with Carb cleaner and did nothing but mess up the sensor and make it stay a idle at 1500
Old Nov 8, 2011 | 11:39 AM
wvubeerman's Avatar
also, could replacing the v-tech o rings help this issue out, the guy that did the timing belt said that they needed replaced?
AdamBl
Apr 27, 2011 07:41 PM
MinimalXistance
12
Apr 15, 2006 12:24 AM
staticchmbr
Apr 14, 2004 04:54 AM
