wheel studs
Old Nov 7, 2011 | 10:06 PM
guru350's Avatar
Default wheel studs
can anyone find a DIY or any info for extended wheel studs on a 95 ex cd5 i ve searched but cant find anything
Old Nov 8, 2011 | 03:30 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: wheel studs
What exactly are you looking for? Which ones to use, how to do it, etc?
Old Nov 10, 2011 | 09:51 PM
guru350's Avatar
yes a how to .....step by step
Old Nov 11, 2011 | 12:14 AM
MAD_MIKE's Avatar
MM Gruppe B
OOMPF
You do realize just to GET to the front hubs is a major PITA.
*Some longer studs require the old stud holes to be knurled or reamed out. If so, you must do this, if not the studs will cause the hub to deform and the studs will not be parallel to each other.*
Procedure Front
Remove engine splash shield.
Remove hubcaps
Un-stake and loosen CV axle nut.
Loosen front lug nuts.
Jack front of car up at front jack point, place jackstands under frame rails.
*If using four, the other two under the front beam bolts at the corners.*
Remove front wheels.
Remove axle nut
Remove flexible brake line bolts to shock, remove line from shock.
Remove flexible brake line bolts to knuckle, remove line from knuckle.
Remove ABS sensor(if equipped) bolts to knuckle, remove sensor.
Remove caliper cage bolts to knuckle(not caliper to caliper cage bolts).
Between the fender lip and upper shock mount there will be a plastic plug, remove it.
With tie wire or twine, tie it around the large center hole in the front caliper, and the other end to the upper shock mount. Hang caliper up high, make sure not to bend/twist flexible brake line hose. Use the plugged hole as a pass through for the wire/twine.
You can also try to hang the caliper/caliper cage off the radius rod.
Remove sway bar end link
Remove cotter pins from tie rod, upper BJ and lower BJ castle nuts.
Remove tie rod nut, flip, reinstall so the flanged part is flush with the stud. Strike with a hammer to pop tie rod free. Remove nut, remove tierod.
Remove upper BJ nut. Flip and reinstall it so it is flush with the bottom of the stud.
Strike with a hammer to pop the upper BJ free. Leave nut on for the moment.
Remove lower BJ nut. Flip and reinstall it so it is flush with the bottom of the stud.
Using a floor jack, place the cup directly under the inverted nut and jack the arm up via the nut. It should pop free, you may need to strike the lower control arm with a hammer with a stubborn stud. Lower jack. Remove nut, remove BJ from FLCA.
Pull knuckle away from the body, and remove the stub axle. Be careful of outer CV boot, wrap in rag/towel for protection.
Remove the four bearing bolts, replace with longer bolts.
Wear ear plugs/muffs.
Using 5lb single jack(mini-sledge) and using an assistant(or some means of securing the upper portion of the upright to a work bench) leave the hub/rotor/bearing overhang the bench, begin hitting the heads of the longer bolts in a star pattern until the bearing is free from the upright.
Remove longer bolts, remove hub/rotor/bearing assembly.
Remove four hub to rotor bolts.
Remove rotor.
*fun part* Remove bearing from hub.
Remove studs from hub.
Knurl or ream out stud holes, if needed.
Install new studs.
Originally Posted by Chilton/Haynes
Installation is the reverse of removal.
Procedure Rear
Place hand/parking brake on.
Remove hubcaps
Loosen rear lug nuts.
Jack rear of car up at rear jack point, place jackstands under frame rails.
Remove rear wheels.
Remove dust cap
Un-stake and loosen spindle nut.
Remove caliper to hub screws.
Make sure hand/parking brake is off.
Remove caliper/caliper cage from rear knuckle.
Remove rotor.
Remove spindle nut.
Remove hub assembly
Press out stock studs.
Install new studs.
... or something like that.
Old Nov 11, 2011 | 04:31 AM
H-T Order of Merit
How much longer do you need them?
Old Mar 17, 2012 | 03:00 PM
ccrawley's Avatar
I have removed the upper ball joints but the lower won't budge. Are there any suggestions on how to get the knuckle free from the lower ball joint? I have tried a jack and a hammer. No success either way.
Old Mar 17, 2012 | 03:02 PM
ccrawley's Avatar
Old Mar 17, 2012 | 03:11 PM
BoosterB16's Avatar
to remove the lower ball joint, use a pickle fork with an air hammer or normal hammer.
Old Mar 17, 2012 | 03:19 PM
bob441's Avatar
Jack the lower arm all the way up then put a 1/2 inch Craftsman ratchet in the space right behind the ball joint ,let jack down fast and it will pop it out. Look for the Eric the car guy videos on you tube will save you alot of time. also DO NOT BEAT YOUR BEARING OUT you will have to replace it use a puller
Old Mar 17, 2012 | 06:51 PM
djkurious's Avatar
http://www.youtube.com/watch?v=ISY8bGof3bQ
Old Mar 17, 2012 | 09:31 PM
ccrawley's Avatar
I finally got it loose after several tries. Thanks guys. Now I have to find someone to press these hubs so I can replace the wheel studs. Thanks again.
Old Apr 7, 2012 | 08:49 AM
ccrawley's Avatar
well everything is pressed and put back together but I have this horrible scraping noise and some drag on the driver side front wheel. Any suggestions on what it may be and how to fix it?
airikkCRX
Jan 16, 2010 04:31 PM
heyimrchills
Jan 3, 2010 05:43 PM
rollercosta123
Mar 10, 2006 08:01 PM
xmilanoredsix
Sep 2, 2004 05:31 AM
SEA Hag
Jan 9, 2003 06:15 PM
