Oxygen Sensor burned in two weeks??
I have an EF9 and about two weeks my car stopped turning on, I took it to the shop and they told me that the spark plugs had oil, the fuel injectors were not working and neither was the injectors. Two weeks later the oxygen sensor once again is burned, and they told me that it has to be the catalytic converter, but someone else told me that it could be a valve... any suggestions???
is your ef9 an sir or sir-2? the 2 is a pretty cool car with abs and all that...plus the right hand drive thing probably gets lots of looks.
anyway you may want to rephrase your questions since they do not make any sense.
what did the shop find wrong at first and what did they replace? and when you say does not start...does it crank? is the check engine light on?
0260MOTORSPORTS
Dec 23, 2006 02:59 PM
