D16Z6 Conversion From AT to MT
Old Nov 7, 2011 | 05:24 PM
TEGGYRR's Avatar
Default D16Z6 Conversion From AT to MT
I acquired a Z6 for cheap knowing i'd have to convert it to manual from automatic. I had the parts, ( Flywheel, Clutch etc..) I read somewhere if i remember right, that i'd have to switch the intake manifold to a IM from a manual.
Would you guys recommend i use the B8 IM i have or get a Z6 IM for Manual transmission?
Second issues is the wiring on the engine. Should i swap it to a B8 Harness or keep the Z6 Auto. It won't be a problem to wire up Vtec on the B8 Harness. I just don't want to have problems in the future.
Old Nov 7, 2011 | 05:27 PM
vinem1's Avatar
Default Re: D16Z6 Conversion From AT to MT
I would get the Z6 IM for Manual transmission to avoid headaches but of course is up to you.
Old Nov 7, 2011 | 05:36 PM
Linked's Avatar
you don't need an manual z6 IM, your auto one will work fine with it
Old Nov 7, 2011 | 06:07 PM
strategy400's Avatar
How much for the auto trans?
streetelementcc
Oct 8, 2011 09:19 PM
starkyreddc
May 22, 2009 03:12 AM
D16Z6_turbo
Feb 14, 2005 08:28 AM
wpgcivic
Nov 20, 2004 09:40 AM
