Eg Wiper Issue
Hi guys... I have a small problem it may be an amateur question but my wipers arnt working... the fuse is fine... the sprayer works fine... and i replaced the motor with one from a working eg and its still not working... where should i look next
Thanks
Thanks
I tested the 20 A Fuse labeled Wipers, spray ect... I dont have any tools to check but i did put in a spare fuse and on top of that since the wipers and spray are in the same category (unless i f'd up) and the spray worked it should bean the other one will work too. I sont know how to test the switch and i dont have a voltmeter.
All i can say is that it was working, and then while changing speeds it kind of jerked a bit i shut it off immidiatly and dosent operate since. The motor makes no noise
PaChiLa Leader
Apr 26, 2013 12:19 AM
D16Z6racing
Mar 25, 2012 09:20 AM
