Violent shaking under acceleration!!!
Old Oct 6, 2002 | 06:26 PM
itr1236's Avatar
Default Violent Shaking under acceleration!!!!
I need to get some opinions from you guys. I have a problem with my R under acceleration. When I accelerate the car shakes pretty bad. The harder the acceleration the worse it gets. I am thinking that it could be the axles because they were replaced once before and now the ones on there are remanufactured honda axles which I have heard suck. Is there anything else that you guys think it could be. Not the balance of the wheels, and I don't think it is anything in the tranny because I just got a lot of things replaced inside, and the guy who did the tranny said the diff and everything else looked fine when he was done. Any help would be great. Thanks.
Old Oct 6, 2002 | 06:31 PM
Reid's Avatar
Global Moderator
Default Re: Violent Shaking under acceleration!!!! (itr1236)
Does the car pull in any direction under decceleration or acceleration?
Old Oct 6, 2002 | 06:37 PM
BDiddy's Avatar
Default Re: Violent Shaking under acceleration!!!! (Reid)
motor mounts? Everything connected if you had major work done? Broken?
Old Oct 6, 2002 | 06:44 PM
ZygSpeed's Avatar
Sounds like probably axles, or bearings.
Check your lugnuts too.
[Modified by Zygspeed, 10:45 PM 10/6/2002]
Old Oct 6, 2002 | 06:50 PM
itr1236's Avatar
Default Re: Violent Shaking under acceleration!!!! (Zygspeed)
No the car doesn't pull in any direction, I checked the lugs, which bearings are you talking about? Anyone else have any opinons??
Old Oct 6, 2002 | 07:00 PM
infinkc's Avatar
sounds like your axles, i have some cheap ones on my car and like every 10k it seems i have to replace them they just keep wearing out.
ZygSpeed's Avatar
Wheel bearings.
Still could be you've thrown a wheel weight, unless they were just balanced.
How many miles, and do you track the car much?
Old Oct 7, 2002 | 05:36 AM
itr1236's Avatar
Since I got the car back from the first axle replacement, I have only been to one autox and I have gotton on the gas about ten times. I haven't been driving it that much lately, but it seems to be getting worse and worse.
Old Oct 7, 2002 | 06:06 AM
b19coupe's Avatar
Inner c.v. joints can cause the vibration you are talking about. Seen it more than once.
Old Oct 7, 2002 | 09:17 AM
itr1236's Avatar
Default Re: Violent Shaking under acceleration!!!! (b19coupe)
O.k. I got the car up in the air this morning to see if I could check anything out. What I found was that there was a lot of play where the axle and intermediate shaft connected. And also some play where the other axle went into the tranny. The intermediate shaft is still an itr one, and I am positive the remanufactered axles aren't from an itr, so I am assuming that this is my problem. Thanks for all of the help.
Old Oct 7, 2002 | 09:28 AM
ITR#00-1077's Avatar
Change the axles... how low is your car??? that has a dramatic effect on how long your axles will last... axles are made for stock height.. and usually all axles are remanufactured... and if you get them from a local parts store... they usually have lifetime warranties on them so just use them, break em, then replace them for life.. that's what I had on my old GSR... and since I still have the original receipts.. everytime the axles go out.. just get new ones.. for free...
Old Oct 7, 2002 | 09:37 AM
JDM nerbie's Avatar
New User
you can buy two different types of reman. axles.
1)with rebuilt joints or 2) with brand new joints
check which ones you got. the rebiult ones last only about three months or so. and are cheaper then the others
Old Oct 7, 2002 | 09:55 AM
Honda318dx's Avatar
Bingo, its the inner CV joints.. Went threw this problem with an accord not to long ago that was using cheap axles, get them from http://www.raxles.com
Old Oct 7, 2002 | 10:57 AM
itr1236's Avatar
Default Re: Violent Shaking under acceleration!!!! (Honda318dx)
The car is lowered about 2-3 inches. Are the axles from raxles high quality, and will they last??
Old Nov 25, 2003 | 01:18 PM
Mach30SiR's Avatar
is there a way to tell if its the inner CVjoint?
I just got my axles done today and i''m having this problem
by the way is a jdm h22a prelude 93
thanks guys.!
Old Nov 25, 2003 | 01:41 PM
JDMTYPER's Avatar
Default Re: Violent Shaking under acceleration!!!! (Mach30SiR)
I just had this same problem and it was my axel.
Old Nov 25, 2003 | 02:29 PM
Mach30SiR's Avatar
Default Re: Violent Shaking under acceleration!!!! (JDMTYPER)
thanks, they tried tot tell me it was my engine mount, and i dont have an once of wheel hop, i'm sooooo pissed
improper ballance?
Old Nov 25, 2003 | 03:45 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1236 &raquo;</TD></TR><TR><TD CLASS="quote"> Are the axles from raxles high quality, and will they last??</TD></TR></TABLE>
I run Marty's axles. They have held up very well on my car with 30 or so passes on slicks and 30K miles on 1.5-2.5" of drop.
Old Nov 25, 2003 | 06:22 PM
K20DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1236 &raquo;</TD></TR><TR><TD CLASS="quote">O.k. I got the car up in the air this morning to see if I could check anything out. What I found was that there was a lot of play where the axle and intermediate shaft connected. And also some play where the other axle went into the tranny. The intermediate shaft is still an itr one, and I am positive the remanufactered axles aren't from an itr, so I am assuming that this is my problem. Thanks for all of the help.</TD></TR></TABLE>
if thats so then your diff bearing is shot that causes the shake also are you leaking any trans fluid? if not also rm axles sux ***. assembled in mexico and stuff like that.
Old Nov 26, 2003 | 01:08 AM
TurboR1391's Avatar
I had the same problem on my 95 Integra and it was a bad axle.
Old Nov 29, 2003 | 08:40 PM
typerman's Avatar
Default Re: Violent Shaking under acceleration!!!! (TurboR1391)
I had the same problem,i am gonna guess that u have some kind of coilover set up on the car,if u do try raising the height of your car a few inches in the front and see if it stops(worked for me)
00 py r 326
03 EVO 8
I LOVE MY R
Old Nov 29, 2003 | 09:09 PM
.RJ's Avatar
.RJ
inner cv. had the same problem on my RS last month.
Old Nov 29, 2003 | 11:06 PM
1 2 NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Inner c.v. joints can cause the vibration you are talking about. Seen it more than once.</TD></TR></TABLE>
this is exactly how i diagnose all my broken axles at the track, violent shakin under acceleration = inner CV joint.
Old Dec 14, 2003 | 02:54 PM
93-GSR's Avatar
Default Re: Violent Shaking under acceleration!!!! (1 2 NV)
The search function realy does work! I could have posted the same ? but instead I searched for 5 seconds and found my answer....thanks guys!
1bar_ek
May 18, 2008 04:44 PM
xtremegsr273
Jan 25, 2006 12:53 PM
jordanb1
Dec 26, 2005 08:58 AM
steronz
Apr 5, 2005 02:41 PM
Kalokohan
13
Jan 15, 2003 07:08 AM
