H22 swap and cruise control
Old Oct 6, 2002 | 06:16 PM
m0t0rhead's Avatar
Default H22 swap and cruise control
For those of you that swapped their motors for H22A's.. were you able to keep your cruise control ?
Did you lose any functionality at all after the swap ?
Old Oct 6, 2002 | 08:46 PM
MyBigNut's Avatar
Default Re: H22 swap and cruise control (Escobar)
i know a person with a swap.. he had to take out the cruise control
Old Oct 6, 2002 | 09:02 PM
KTeller8's Avatar
Default Re: H22 swap and cruise control (MyBigNut1)
had to take mine out. i suppose you could try to rig it. but the ludes didnt have it and there wasnt anywhere to add it in a stock fashion. i took out my assembly and said oh well. i dont use it much anyways
Old Oct 7, 2002 | 04:09 AM
m0t0rhead's Avatar
Default Re: H22 swap and cruise control (KTeller8)
That sucks! I use cruise all the time
Old Oct 7, 2002 | 07:39 AM
Nick M's Avatar
I took mine out as well.
Old Oct 7, 2002 | 08:25 AM
GZERO's Avatar
i haven't done the swap, but i been reading a lot in here and i heard of some people that did it, but i don't know if it was the H22A or the H22A1-4, do a search and see what you can find
Old Oct 7, 2002 | 11:00 AM
CD8's Avatar
CD8
Default Re: H22 swap and cruise control (GZERO)
no p/s for me
Old Oct 7, 2002 | 11:50 AM
ichibanjap's Avatar
Default Re: H22 swap and cruise control (exaccord)
I don't have cruise control either and i heard if you want it, it's a pain in the *** to get to work.
Old Oct 7, 2002 | 12:01 PM
KCHybrid's Avatar
The H22a and the f22's have it on differnt places, the accords is on the throtle body. I am unsure of where the h22a's is. I have read that you can use the accof tb and keep it or i have been told that if you buy the 97 tb for a usdm h22a that you can get it to work. I am going to find a way on mine, its handy sometimes.
Old Oct 7, 2002 | 03:06 PM
purpl7duece's Avatar
Default Re: H22 swap and cruise control (KCHybrid)
No cruise in my 92 accord, Or A/C. Or P/S or heater. Damn I need to have A/c though.
Old Oct 8, 2002 | 06:23 AM
KTeller8's Avatar
Default Re: H22 swap and cruise control (purpl7duece)
h22 in 96, have ac/heat/ps and if i really really wanted to be lazy i am sure i could figure how to add that second line for the cruise control
Old Oct 8, 2002 | 06:37 AM
Jason kiDD's Avatar
Hmmn that is weird. I had a 91 Accord with a 98 JDM h22a and had everything hooked up without any problems. AC, PS, Cruise all worked and was located in stock fashion. Only thing of course is that you had to use the prelude PS line to fit..
Old Oct 8, 2002 | 08:34 AM
KTeller8's Avatar
Default Re: H22 swap and cruise control (Jason kiDD)
hmm, there isnt a spot on my h22 and i was told that they didnt offer it with cruise
Old Oct 8, 2002 | 03:54 PM
m0t0rhead's Avatar
Are you saying there aren't ANY usdm H22A's that came with cruise ?? no way !
I was unaware of that.
Old Oct 8, 2002 | 11:28 PM
Damn I need to get this **** hooked up what do I need to run A/C in my 92 acord with a 2k H22a4 It has the Lude compressor on it but no condensor or other **** like that.
Old Oct 9, 2002 | 06:46 AM
KTeller8's Avatar
i was told this. call your local honda dealer parts ppl and ask. if it was offered then they would have some part numbers
I was told that no 92-96 had them.. yet i think that Vtec didnt pop out till 93
Old Oct 9, 2002 | 10:22 AM
KCHybrid's Avatar
They started production in JDM land back in 92. Hard to belive they have been around so long.
Old Oct 9, 2002 | 11:28 AM
TouringAccord's Avatar
H-T Order of Merit
That can't be right. My friend bought a 94 or 95 Lude VTEC a few months ago and it had cruise control. When I looked at his engine bay the only thing that was different from mine(F22B1) to his USDM H22 VTEC (not sure of engine code) was where the cruise control was placed. In the Accords there in the back against the fire wall and in the Prelude it's up by the front driver side headlight area.
Old Oct 9, 2002 | 02:40 PM
m0t0rhead's Avatar
Default Re: H22 swap and cruise control (TouringAccord)
That's weird. Most cruise control setups I see are connected to the throttle body with a seperate throttle cable...
weird.
Old Oct 9, 2002 | 04:30 PM
BlazingSIRT's Avatar
I have a 94 JDM H22A in my 96 Accord EX. I was able to keep both PS & CC. I needed to get a PS hose from a Prelude to match up with the pump. As for the CC, I had to shorten the cable and change the direction of where it came from. Similar to how you have to change the throtle cable (not have it go over & around the motor like it did on the F22). Also, I can't remember, but I think I needed to use the F22's TB. The one that was on the H22 didn't have any spots for the cable. Hope this helps
[Modified by BlazingSIRT, 6:33 PM 10/9/2002]
Old Oct 9, 2002 | 06:16 PM
HidPerf's Avatar
Default Re: H22 swap and cruise control (BlazingSIRT)
The 94-97 Accord cruise hooks to the throttle body. The Ludes hook to the gas pedal. The only way it will work is to use the Accord Type-R / Euro-R throttle body. I am currently working on getting these for my own swap.
Old Oct 10, 2002 | 03:34 AM
H-T Order of Merit
weird.
Ooops. Sorry, forget what I had said. I was thinking backwards. I was thinking about the other end of the cruise control cable, not the end that connects to the TB. Now that I think about it, I never did look to see where it connected.
Old Oct 10, 2002 | 08:50 AM
Boosthead's Avatar
I have A/C and cruise in my 91 Accord with 99' USDM h22. I'm using the accord PS pump and bracket. As for cruice control. I don't have it hooked up, but that's my next project
Old Oct 11, 2002 | 02:34 AM
Hotrod Honda's Avatar
I have an H22A in my 90 Accord and I have my Cruise Control on..... and yes Ludes do come with Cruise Control....
DevontElan
Jan 18, 2005 03:45 AM
G2DAteg
Oct 19, 2004 06:01 AM
grown_up_wagon
Aug 23, 2004 09:32 PM
