99 accord temp gauge fluctuating.
Old Nov 7, 2011 | 12:10 PM
ASLinterpreter's Avatar
Default 99 accord temp gauge fluctuating.
Hello all! I have a 99 accord with 305,000 miles. Recently I have noticed that the temp gauge will all of a sudden drop all the way down, then a few minutes later come back to normal. It never goes high, it seems to just not sense anything and go back to where it starts when the car is off. The coolant level is good.
Any idea what's happening??
Thanks for your time.
Jeffrey
Old Nov 7, 2011 | 12:45 PM
redbull-1's Avatar
Default Re: 99 accord temp gauge fluctuating.
You checked the coolant level in the radiator and not just the reservoir?
If so, then check the temp. gauge sender wire connector, it should be a one wire connector under the distributor. (This is for a 4 cylinder, if it is a 6 cylinder, let me know.)
If wire and connector are good and coolant level is good, it may be the gauge sender unit.
Old Nov 7, 2011 | 12:54 PM
It's a 4 cyl. Thanks so much!!!
Agent Daimon
Nov 29, 2015 02:25 AM
dr.deuss
Feb 5, 2015 03:47 PM
ffemt
Jun 30, 2012 06:53 PM
ZCHondaCRX91
May 15, 2012 06:33 AM
Chuck Dean
Mar 24, 2005 09:59 AM
