To LSD or To not LSD
Old Nov 7, 2011 | 07:16 AM
jakoh77's Avatar
Post To LSD or To not LSD
I planning to have a car with close to 250ftlbs or torque. I have a boosted b18b1 with forged internals but stock head, and i'm leaving the head stock for right now. So with that being said its going to be rev lim. at 7200rpm. Since its going to be low end torque, I'm choosing to stick with the LS tranny because of the longer gears. So my question is this. To add LSD to it or not. I did buy some carbon synchro's and those are going in, but I cant decide if its worth it to get an LSD for it or not. If money wasnt an issue then I wouldnt worry about it but it will cost close to $900 for the LSD. It comes down to the pro's and con's I suppose. What are the chances that I blow up the tranny without it? Will I be able to launch without it or is that too dangerous?
Old Nov 7, 2011 | 08:04 AM
TheShodan's Avatar
Moderator
Default Re: To LSD or To not LSD
That's like asking.. Do I want to control the car, or not to have control. "Blowing up the transmission" is going to be determined by YOU, and you're ability to act appropriately for controlling the car.
BTW "Longer gearing" for turbocharging is not the reasoning for keeping the LS transmission. That's an old myth. "Being in boost longer" means nothing if you're not accelerating.... Having that said, in your case with a full stock LS, your transmission choice is fine.
Also, do us a favor, and keep all these big questions you have in ONE thread.. You have 2 threads on here, so don't make anymore for a bit. We're here to help, but keep the number of threads limited.
Old Nov 7, 2011 | 04:40 PM
Schister66's Avatar
Man U FTW
^^ Listen to him...
My biggest regret is not running an LSD. I have since compensated for that mistake...my STi has 3 of them
Old Nov 7, 2011 | 04:49 PM
LightningTeg's Avatar
Community Builder
I love my LSD. Its nice when the car doesnt pull to the side that hits a pot hole
Old Nov 7, 2011 | 05:26 PM
1158's Avatar
My previous setup had 250 ft/lbs and would spin through 2nd without using boost by gear with an LSD.
You want an LSD.
Old Nov 7, 2011 | 05:33 PM
welfarepc's Avatar
lsd is worth it just for piece of mind and reliability sake
edit: not to mention the additional performance benefits!!
Old Nov 7, 2011 | 06:16 PM
Schister66's Avatar
Man U FTW
To add to my previous statement:
My car makes 285wtq and spools fairly quick...without an LSD, i can barely hook up on the street (under ~50mph) unless i'm using drag radials. DR's can help out, but they're not a miracle cure. Even though i dont get massive wheel-spin, torque steer still is a factor
Old Nov 10, 2011 | 02:58 PM
Cantcatchme's Avatar
You want a lsd. Its a pain trying to launch you car without one.
Old Nov 10, 2011 | 05:10 PM
b18cya94's Avatar
lsd all the way.. the stock diff is the weakest link in a honda trans..
Old Nov 10, 2011 | 09:39 PM
Prozon's Avatar
Go with it. You will beat yourself up later down the road if you skip on the LSD. I know I regret not adding one in when I rebuilt my transmission.
Old Nov 12, 2011 | 09:13 PM
CDecker0218's Avatar
hands down you should get a lsd. Reason I didnt run my car at the track this year was due to not having one
Old Nov 12, 2011 | 10:04 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
buy an mfactory from a good distributor, they aren't more than 800 shipped
ctr32
Feb 18, 2010 10:48 PM
Ruben19
Jan 17, 2006 04:50 AM
93b16CivicSi
Aug 13, 2005 12:12 AM
one8toh8
Jul 14, 2004 08:28 AM
CRX A4
Apr 5, 2003 04:04 AM
